Lighting issue
Chase
Naperville, IL
Not sure what to make of it but my whole passenger side lighting doesn't work other than the bright. All the wiring is in tact and hasn't been hacke into at all. I'm not sure what the issue is but I figured I'd see if anyone else has had this issue.
fuel
Toronto, ON, Canada
installed a stereo recently?
Chase
Naperville, IL
It has a stereo yes but I didnt mess with the wires on it at all. All the wiring there was done. And yes I didnt hack any wiring at the light itself and have gone over the harness there.
quicktsi
Yukon, OK
Passenger front or rear or both? Have you checked the relay on the passenger fender side? The wires had be eaten around the relay on mine prior to buying it?
Chase
Naperville, IL
Just the front passenger side. The regular beam headlight and the corner light. Everything else is fine.
sandthng
Member
Helendale, Ca
Have you tried switching the bulbs around, to verify that it is the wiring? Could be as simple as bad bulbs.
Diego
Quoting quicktsi:
You too had animals living in the engine bay upon purchase? Mine was like prairie dogs... /ubbthreads/images/graemlins/shocked.gif
Chase
Naperville, IL
Yea the bulbs are fine. I actually wired it to the other side to make it work for now but it's not a great solution by any means.
No animals in the bay.
