Picked this up from craigslist for approximately 2000$ it started and ran with no abnormal noises but had a high idle. Did not run when warm.
Pulled the ecu and it was pretty toast. Got a used one for 75$ and threw her in today.....Its ALIVE. Still has a very high around 1500-2000rpm COLD idle, when warm it has a lumpy 800-900rpm idle where i can hear the throttle "shudder" causing the lump in the idle.
Drove it around the block and it all seems good. I removed the bcs restriction plug. I started to hack the top of the airbox, but decided to wait to finish until after the smog /ubbthreads/images/graemlins/grin.gif
Goods; records up to 120,000mi like you cant imagine so about 20-30,000 unaccounted for by second owner. Everything is there and it runs, builds boost etc even the original stereo works! no major dings or body problems!
Bad; rear seats torn need upholstery, headliner is in poor shape, sunroof wont open all the way but vents and closes properly. glovebox latch is broken so i have the entire right side underdash removed. the paint is a bit faded could use a buff and wax, underhood is really dirty, and the front brakes are pretty poor shape.
onto the pics
/ubbthreads/images/graemlins/uhh.gif
onto the pics
