89 center tailight section?
Wilfongtsi
Fort Wayne IN
Will the 89 center taillight section fit on the 91, 92 trunks? I've heard they won't, just tryin to find out for sure. I think they also don't have lights in them or sunthin? /ubbthreads/images/graemlins/dunno.gif
CP
West Simsbury, CT
He's asking about the unit I've got for sale:
The body is the same (base Galant vs GVR4) so I don't see why they wouldn't bolt right on exactly the same as the stock center section...
It fits but will look like sh*t without the other two sides.
The sections wouldnt line up at all.
^BTW Cy your picture has the section upside down.
Wilfongtsi
Fort Wayne IN
Thanks for adding pic. I just like the way the clear part matches the color on the taillights, and I'm going for a badgeless look so no vr4 emblem.
I'm pretty sure they are different. I have an 89 center section and a 91 spare center, and the mounting studs are not all in identical locations. They can maybe be moved/removed, so it may fit, but not mount exactly the same.
^Ok I posted a picture of my car, which is a 91 with 89 tails for reason. It fits!
You dont use all the nut on the back side but other than that it works fine.
DR1665
Iowa City, IA
I went to install a set of these, myself, found the center section doesn't light up, and then realized I wasted $40 buying them. :p I got them because I like the way the amber turn signals are on the top - like on my Talon. Some day, I might even snag a grille from an Eagle Summit and swap it in the front just for shits and giggles...
wowzer
CS, IL
2000GTX is an exact fit Summit is different.
You should be able to switch tails.
Polish
NE, IN
My center section lights up on my 91 but has no badge, it's on the trunk lid.
CP
West Simsbury, CT
Oh that's right, I pulled the bulbs out of my center section taillights. I thought it looked ghey with all that red back there. I was thinking about wiring up a really bright bulb on one side of the center section with a manual switch to be used as a rear foglight, ala Saab, Audi, Volvo.
I also misted some dark spray paint on my license plate bulbs so it doesn't have sun-like beacons illuminating it.
IncorpoRatedX
Arizona
I had a wingless 90 decklid and i put my 91 tail light center section in it without any issues. So as far as i can tell they're interchangable.
