Someone Please Measure the AC Bracket thickness?
desant78
Clarksboro, NJ
Hello All
I am putting a vr4 together, and need to make a spacer for the driver side CV shaft to mount to the motor. The car does not have the AC bracket, and the only one I own is in my car.
I was wondering if anyone could quickly measure the thickness of this mount where the CV shaft bearing carrier is so I can make one to replace it.
Thanks in advance!
Another solution would be to install the jack shaft bracket with only the one bolt that doesn't need a spacer (pretty sure it's the one closest to the passenger side) and just measure the gap between the bracket and the block where the other bolt goes. I had to do this on 1813 as well. I used a piece of round stock cut to the right thickness, and then drilled a hole in the middle for the bolt.
89Mirageman
Stantonsburg, NC
Not sure if it's the same part or not but Mitsu sells a spacer for 1g awd dsm's that didn't come with AC. Or hardened washers would work as well using GST's idea above.
desant78
Clarksboro, NJ
thanks guys, I didn't realize you had to only space out one side of the carrier. I'd rather not use washers, because I have more tube/bar stock lying around that would work. Rather not go out and buy washers when I can turn down an actual spacer for free.
If anyone has one lying around and wants to measure it let me know! Next time I'm at the shop, I'll try and measure it how GST suggested. thanks!
Spyke169
Greenfield, Wi
Part # for the spacer is MB297732
Edit: Just reread and realized that may not be helpful if you don't want to spend more money, but for anyone else interested, outside of getting it from the dealer, JNZ sells them as well click
Edit: Ok, ran down to the garage and measured 0.512 inches
desant78
Clarksboro, NJ
Thanks so much!!!
