I will say this.
When you inflate most tires closer to their max cold pressure, you are more apt to wear the shocks internally due to the harshness created from a tire that now bounces/oscillates in a different manner than the factory prescribed. Tread down the center can suffer, but generally I see shock absorbers on domestic cars, and foreign that are worn/leaking and or abnormal tire wear from the combination of excessive pressures and the resulting tire/shock control issues. Instant turn-in, or lack of sidewall rolling over, yes it can have a somewhat desired effect, but I would sermise that the longevity of the shock will be affected. Much like putting a larger tire/rim into the situation, on the same stock shock with weak valving, and then add in a stiffer spring and take the entire setup right out of it's element, and you see where all this is going.
Stock tire pressure ala the OEM will be fine for comfort and how they designed the car to handle. When you go drag racing, you try something lower, when you go auto-crossing, you try something higher and so on. You can run what you want, but you have to know your suspension and what it was designed for. My Passat takes 35psi front, 44psi in the rear. The shocks are valved and made to control the oscillations of said tire and pressure, over "X" road conditions; ie Autobahn, city etc. Some cars have multiple pressure ratings, based upon what size tires you have and what weight capacity you need to accomodate. The more pressure, the higher the weight and less likely to overheat the tire in a given scenario, within limits. Open to door of a BMW and you will likely see many tire pressures and weight scenario's.
It's all in what you are comfortable running, and how you feel it will affect your equipment. I see this on a daily basis and always find something new in this regard. Heck, we had a Hummer H3 come in and I checked his door mounted Government mandated air pressure label, and it said 37 PSI. Tires were aftermarket mud/all terrain 20/22's and max pressure was 50 PSI cold. Tech beside me says, don't put in 37, go with 85% of the max cold pressure. Life's a box of chocolates ....
