Throttle Body Elbows
JackstandTSi
Columbus Ohio
Ive been looking for a Front mount for my car and noticed almost all of the Elbows bend prety much right off the flange, Is there any elbows that stretch straight out a bit and then start the bend. From previous experience with 1g DSM's i find it a pain to get the bolts in and out of the throttle body housing.
Thank you
Convert to a non turbo 1G throttle body. Problem solved for good.
raptorWagon
Oak Harbor, WA
Or, you switch to studs, because on the ETS kit, it's better off that you do on at least one of the bottom bolts. /ubbthreads/images/graemlins/smile.gif
