91 Galant VR-4 "Slutty Paula"
I had a little impulse buy the other day and picked up this 1991 Galant VR-4. The kid that sold me the car told me it's name was Paula because that's the name of the hot mom he bought it from. I decided that "Slutty Paula" was more fitting since just about everybody and their mom has owned this car in the Fargo area.
It's number 708/2000
Like I said, the car has been around the block once or twice, so I'm not 100% sure what's all done to it, but I do know the following:
-New o2 sensors
-New timing belt
-New valves
-16g
-full exhaust
Like all dsms, there's a few things that need attention. First thing I noticed was the oil pooling in the vc well area. I took the vc off thinking that the gaskets just needed to be replaced and found a big crack /ubbthreads/images/graemlins/frown.gif I plan on tig welding it up tonight, shaving the vc, and powdercoating it.
Future plans:
-Research and fill my head with knowledge
-Throw it on a dyno to get a baseline
I used to own a 98 gsx, so it feels good to get back to my dsm roots /ubbthreads/images/graemlins/smile.gif
-Brian
jogalant
Central FL
Welcome and good luck! Looks like you've got your work cut out for you. No offense but the Galant looks like it's been through hell and back. /ubbthreads/images/graemlins/bawling.gif
I hope it has found a better home and owner in you.
Paula has definitely lived life. Great user name, Brian. Hi, I'm Mike.
Start with the basics, replace vacuum lines, change fluids, change fuel filter and then go from there. Pick up a pocketlogger at the least so you can monitor parameters. Good luck.
Quoting jogalant:
Thanks and no offense taken! I see all the same dents and sadness that you do. The good news is that she runs like a boss.
Quoting 3of1000:
Haha thanks Mike. I try to gap the barrier between introwebs and real life, so feel free to call me Brian /ubbthreads/images/graemlins/smile.gif
The kid I bought it from told me he just had all the fluids replaced from his buddy that works at a dealership here in town, and he had receipts to show for it which was nice. The fluid on the tranny dipstick and in the crankcase looked clean when I checked. I've also got a scangauge II that I have mounted in my 98 impreza 2.5rs that I'll swap between cars for the sole purpose of making sure temps and whatnot are where they should be. I ran dsmlink on my old dsm, but depending on where I go with this car, I might just stick with an safc or somethin.
Quoting turbowop:
...And oh yea...I hear you guys don't like VR-4's being called dsms right? haha /ubbthreads/images/graemlins/wink.gif
Thanks for the warm welcome guys.
-Brian
I actually don't care if you call it a DSM, but others will get on you about it. Figured I'd throw up that smiley as a warning. /ubbthreads/images/graemlins/grin.gif
DR1665
Iowa City, IA
Welcome. Everyone who isn't a FNG and said it's okay to call a GVR4 a DSM has been sacked. /ubbthreads/images/graemlins/hsugh.gif
Looks like the car has had a rough life. Slutty Paula rides dirty. Fun times.
Welcome to the fray.
bmxkid415
Bradenton FL
They say Summit White is the fastest, Just not the fastest at breaking I see.
Welcome to the site!
raptorWagon
Oak Harbor, WA
We don't like it, because of the simple fact that they weren't built in Normal, Illinois like DSMs were, they were all imported from Japan.
Misinformation is Fail.
524of1000
San Antonio, Tx
Those in charge of sacking those who claim it's ok to call a VR4 a DSM have been sacked. /ubbthreads/images/graemlins/grin.gif
Quoting DR1665:
a) what's a FNG?
b) I'm sure she's been beat up pretty good in her day
c) mmm she rides so dirty, but I'm pretty sure she likes it haha
Quoting bmxkid415:
Thanks for the welcome, and heck no...Slutty Paula is holding on to dear life as best she can! I'm going to start looking for a replacement radiator support so I can straighten everything out. Just gotta do some research as to what years are compatible.
Quoting raptorreed:
Do you happen to have any good links as far as history of the vr-4 is concerned? I always thought since they came with the same 4g63 as the eclipse/talons that they were considered dsms. The way I understood it was that dsm = Diamond Star Motors, and Diamond Star Motors was the company that designed the 4g63. I'd really like to read/learn the difference with the Galants vs Eclipse/Talons.
Quoting 524of1000:
Well I don't want to be sacked so I'll keep that in mind /ubbthreads/images/graemlins/wink.gif
Quoting 4wheelsqueal:
Only thing we're missing is the moose's! Oh and welcome to the board!
Not gonna lie...I'm not really sure what that means
Toronto, ON, Canada
haha @ DSM being responsible for the 4G63.. never mind the fact that the 4G63 has been around since 1980.. and that the same DOHC Turbo variant made its debut in the JDM E39A Galant VR-4 in 1987, before DSMs were even around.
alansupra94
Wayne,NJ
Welcome! Looks like you will have your hands full cleaning that up! I know what thats like. A year later and my car and practically transformed!
Quoting raptorreed:
FNG = f***ing New Guy
As per your request and to clear up your complete misunderstanding of what DSM means. A quick breakdown of DSM, Diamond = Mitsubishi, Star = Chrysler, DSM = Joint venture between the two companies.
DSM
DSM
GVR4
Galant History
Brief VR4 Motorsports History
Thank you very much good sir! Those were all pretty informative reads and I feel like a little less of a "FNG" after reading them haha.
Also, I'd like to find a different front radiator support since mine is all sorts of messed up. The only compatible years are the 91-93 Galants right?
Lastly, (for now) I've noticed that the rpms seem to fluctuate up and down quite a bit at idle. I'm going to clean out the MAF and test that along with the TPS. Anybody else have an idea of what else could be causing this issue?
Toronto, ON, Canada
common fault, usually the idle stepper servo motor at fault with a shorted or open circuit coil inside.
I would check out www.vfaq.com for all the frequently answered questions and solutions to most common faults.
I'll start with testing my ISC and go from there. It's been a while since I've used VFAQ, but it's found it's way back to my bookmarks. /ubbthreads/images/graemlins/smile.gif
Idle Speed Control (ISC) testing
DR1665
Iowa City, IA
Quoting HiImBrian:
Correct, though you also want to *really* keep your eyes peeled for an AWD model (meaning one of the less than something like 5000 GSX/VR4 models). Take a look at how that front crossmember (the one with the front motor mount on it) bolts up on either side of the car. Those bits are different on the more common FWD models. You could still use the FWD core support, but you might have to fab up something like this.
More info: click
