Galant VR-4 Forums » Galant VR-4 » Newbies » TPS lower bolt access
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 1247119 posted 09/04/19 01:36 PM     Remind Me!  Send Private Message   Edit Post
Anyone have a trick tool to access the lower TPS bolt/machine screw without removing the fuel rail?
I'm pretty sure 12 years ago I rigged something up to loosen this one even though I obviously didn't adjust it properly since I'm seeing .60V at idle instead of .63V
I was thinking of cutting off a phillips bit and grabbing it with a needle nose vice grips?
I tried a set of craftsman right angle "distributor" wrenches, but the 8mm is too awkward to get a bite.
Of course I can remove the fuel rail but that's sort of a pain. I'm sure there is a trick to it.
Thanks,
PJ
#490/1000
Posts: 1555 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (204.117.38.42) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1247120 posted 09/04/19 01:39 PM     Remind Me!  Send Private Message   Edit Post
I replaced mine with hex heads. Makes it easy to loosen and tighten with the rail in place.
Thom
Posts: 894 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2600:1700:6c83:0) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1247122 posted 09/04/19 02:16 PM     Remind Me!  Send Private Message   Edit Post
Stock are hex heads (8mm) with philips or JIS (I don't remember which)in the center.
So my question is how to you get anything on your hex head? A standard 1/4" socket has no room for a rachet once on. It barely clears the fuel rail on and off without a rachet. Maybe I'll just grab the socket with a long nosed vise grip.
Guess that's my answer. Could tear up the socket but at least it will be loose.
My 8mm gear wrench interferes with the TPS or that would have been great.
I think if there was an 8mm 1/4" drive crow's foot then maybe that would work, but it's a pain in the butt for fat fingers down there.
Thanks,
PJ
I think the tool I used last time was a really old gearwrench type rachet that accepted short stuby Philips bits in it. That thing is long gone now.
#490/1000
"Just to be pedantic!"
Galant VR-4 org Post #: 1247123 posted 09/04/19 02:16 PM     Remind Me!  Send Private Message   Edit Post
I just remove the whole throttle body and set the TPS and throttle stop on the bench.
Posts: 2151 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (199.243.178.67) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1247124 posted 09/04/19 02:18 PM     Remind Me!  Send Private Message   Edit Post
I mean Hex heads, that use allen wrenches. Hex is the internal, not external
Thom
JNR
20/1000
Galant VR-4 org Post #: 1247125 posted 09/04/19 03:14 PM     Remind Me!  Send Private Message   Edit Post
Use an ignition wrench...those small combination wrenches, in meyric version of course.
Posts: 9766 | From: ca | Member Since: 04/23/04 | IP: (2600:1012:b04b:e) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1247141 posted 09/06/19 07:59 PM     Remind Me!  Send Private Message   Edit Post
I installed hex socket head bolts in those tps spots. Then use a long set of extended ball socket hex bits to access the bolts from just above the rocker cover.
Like these:
C53A 1 of the ~1500
Posts: 1627 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.58) | Report this post to a Moderator
1 registered and 7 anonymous users are browsing this forum.
Generated in 0.148 seconds in which 0.12 seconds were spent on a total of 14 queries. Turbo powered.
