Galant VR-4 Forums » Galant VR-4 » Newbies » Gear shift lever part number.
FullPEAK
Newbie
586/2000
Galant VR-4 org Post #: 1245095 posted 01/11/19 12:10 AM     Remind Me!  Send Private Message   Edit Post
Hello
Iím looking for the #partnumber for the gear shift lever. I have a 1991vr4 here is a pic of the part
Posts: 22 | From: Rancho Cucamonga ca | Member Since: 09/28/16 | IP: (97.93.136.6) | Report this post to a Moderator
Dan D
220, 221... whatever it takes
410/2000
Galant VR-4 org Post #: 1245097 posted 01/11/19 04:22 PM     Remind Me!  Send Private Message   Edit Post
It's made up of multiple PNs for all the pins and bushings, etc. but the levers are:
MD735587 & MD719188
[image][/image]
#410/2k
Posts: 1153 | From: Brownsburg, IN | Member Since: 02/27/01 | IP: (2601:805:c700:2e) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1245099 posted 01/12/19 09:50 AM     Remind Me!  Send Private Message   Edit Post
The issue that FullPEAK is having is one of matching up shifter arms on his GVR4 trans and the JDM import trans he is now using.
The JDM trans is with his car now (where he is), but the GVR4 trans is away from home and he is having someone remove the arms at this stage.
Thanks for the full diagram Dan D, as that helps show parts on the standard GVR4 trans with part numbers, and with that it can be compared to the JDM arm.
I think he is needing the remove the long swing arm that points out the passenger side (RH side) of the car, as I believe they may be different between the two transmissions, based solely upon a few pictures I have received.
C53A 1 of the ~1500
Posts: 1599 | From: THE Ottawa | Member Since: 03/05/05 | IP: (24.246.8.178) | Report this post to a Moderator
1 registered and 17 anonymous users are browsing this forum.
Generated in 0.084 seconds in which 0.073 seconds were spent on a total of 14 queries. Turbo powered.
