Galant VR-4 Forums » Galant VR-4 » Newbies » Front axle install RESOLVED
mk2davis
398/2000
Galant VR-4 org Post #: 1244793 posted 12/03/18 09:52 PM     Remind Me!  Send Private Message   Edit Post
Is there a trick to getting the front axles to click in place? She's getting dangerously close to running, and while all the bolts on the wheel side line up, the passenger side at least (haven't started on the driver's yet) still seems to slide left and right if I unbolt everything on the wheel side. Maybe tightened down, things just slide into place?
TIA
Edited by mk2davis (12/14/18 12:36 PM)
Posts: 49 | From: Ventura, CA | Member Since: 03/01/15 | IP: (2605:e000:634a:2) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1244796 posted 12/04/18 05:59 AM     Remind Me!  Send Private Message   Edit Post
Check the clip on the transmission end of te axle. Make sure it isn't too snug or too loose
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1244821 posted 12/07/18 07:04 PM     Remind Me!  Send Private Message   Edit Post
Seriously though, these axles are kicking my buttock. The clip looks appropriately loose. Do I need to separate the brake from the ball joint to slam the axle home? The splines are engaging, but the axles looks to still need to go in another half in or so.
866/1000
Galant VR-4 org Post #: 1244832 posted 12/09/18 08:16 AM     Remind Me!  Send Private Message   Edit Post
I would remove the caliper/bracket and disconnect the strut. Then you can lock it in.
Thom
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c600:5b) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1244833 posted 12/09/18 09:16 AM     Remind Me!  Send Private Message   Edit Post
Yeah, they can take a decent bit of work to get them to click in with one decent push from a straight on angle.
It can help to use a chemical that is auto trans/diff fluid compatible and will break down or not dilute in a bad way, to put under the
clip, to keep it centered on the axle so the part that would otherwise be sagging below the splines due to gravity, isn't in the way during the push.
Hope that helps.
I use dielectric grease sparingly but there are trans gel products that are auto fluid compatible, not sure about compatibility with diff fluids.
A quick internet search should yield some results.
C53A 1 of the ~1500
Posts: 1589 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.135) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1244845 posted 12/10/18 01:21 PM     Remind Me!  Send Private Message   Edit Post
Passenger side is in! I had to pull the strut off, center the locking room with grease, and the axle slid right in once it got straight.
Eager Beaver
Galant VR-4 org Post #: 1244855 posted 12/10/18 10:18 PM     Remind Me!  Send Private Message   Edit Post
... ^^^ and that is what I was hoping to hear!
C53A 1 of the ~1500
Generated in 0.084 seconds in which 0.069 seconds were spent on a total of 14 queries. Turbo powered.
