Has anyone used this Gumout professional series product
Vr4junkie
Some wack town in CA
I just bought this today for cheap but I don't know how to use the intake cleaner and yes I read the instructions but nothing Helpful if anybody here has used this I would appreciate the advise.
Captn
I haven't used that one but I have used seafoam and it works very well, but the sea-foam intake cleaner came as a spray bottle.
I am guessing the fuel system cleaner is probably the same thing if not very close to what sea-foam is.
Where is the instructions telling you to pour the intake cleaner?
Captn
Vr4junkie
There's no real instructions on how to use it just abounch of warnings and danger and incase of fire instructions but nothing on how to use it I know the other bottle goes in the gas Tank but I was thinking the same as the sea foam in the break booster line but not sure if it goes there.
Captn
Yeah that's where I poured the sea foam, I would do it there too.
Have a friend help you keep the car alive while you pour it.
Captn
Vr4junkie
I'm thinking of putting it in the break booster but its a whole different product so I don't know how it would work out but i'm going to wait and see if any body here has tried it or find more info
a2vr4
Ann Arbor MI
I have always sucked seafoam through a vacuum hose on the intake manifold utilizing a stock hose, with the engine running. Depending on which hose you use you may need to cap the port left open by the hose you are using. I use one of the ports on the throttle body or on the plenum of the manifold. iirc the instructions on the bottle say to use half a bottle (8 oz) per cleaning. After 8oz have been sucked into the engine, shut it down for a few minutes to let it do its magic then start the engine and conservatively bring the rpm up (2-4k rpm) and wait till your exhaust is clear again (it will be thick white smoke for a while) I recommend thinking about where you do the treatment due to the quantity of smoke and noise of reving the engine, I have used out-of-the-way parking lots mostly. It takes me 15-20 minutes on average to clear the engine of the seafoam. Hope this helps!
~Brian A. Moreno
Vr4junkie
Note to self not the same as sea foam yea it smokes but takes a good while to start the car almost thought I messed it up /ubbthreads/images/graemlins/shocked.gif
