Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Re: Got another one
Re: Got another one
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1245881 posted 04/18/19 10:00 PM     Remind Me!  Send Private Message   Edit Post
Update:Scirocco Rad and 1g drag ETS 3 inch intercoole. I had to work on the filler neck hose and vent. I ran new hose and matched a filler neck hose up and put new hardware om the filler neck its self. No fuel leaks. Tomorrow I am hoping to button up the brakes.
565/2000
699/2000
Posts: 370 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (2606:a000:1018:4) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246070 posted 05/11/19 10:21 PM     Remind Me!  Send Private Message   Edit Post
Got it running. Car is on E85 and 2200cc injectors and Hellcat 525 fuel pump. I just need to bleed the clutch and the brakes and install radiator and intercooler and piping and test drive
Edited by Terrance362 (05/11/19 10:25 PM)
minneSNOWta
Member +
1899/2000
Galant VR-4 org Post #: 1246073 posted 05/12/19 12:03 AM     Remind Me!  Send Private Message   Edit Post
Nice! Is the budget car going to be more for street use compared to the money pit?
#1899/2000 - W09 A71 (1/111)
Posts: 360 | From: Blaine, MN | Member Since: 05/14/11 | IP: (75.134.141.116) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246075 posted 05/12/19 11:34 AM     Remind Me!  Send Private Message   Edit Post
Yes most definitely. I spent some money on this build but not big money. I didn't want to over build it but I also didn't want to be super slow. I feel like its a nice street car that I can enjoy and beat on and take my kids for rides in.
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246076 posted 05/12/19 11:38 AM     Remind Me!  Send Private Message   Edit Post
Found a little time to feel the trans and tcase. I still need to bleed the clutch more and order shifter bushings. But here you go guys.....
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246109 posted 05/15/19 08:41 PM     Remind Me!  Send Private Message   Edit Post
Hope to install my Radiator tomorrow. My fab guy welded mounts on my Radiator and it came out good.
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246194 posted 05/26/19 10:02 PM     Remind Me!  Send Private Message   Edit Post
Got everything together and the water pipe started leaking. I got pissed and took everything apart. I got the pipe back and I hope to get it back together tomorrow.
565/2000
699/2000
Posts: 370 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (45.36.49.140) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246221 posted 05/29/19 03:47 PM     Remind Me!  Send Private Message   Edit Post
Got the car back together. No leaks!!! I loaded up a new tune and now its not dumping fuel anymore. Runs smoother now. Even cleaned up some of the jankey wiring. I still need to address the rear driver side brake caliper.
Mounted the MAP sensor to.....
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246408 posted 06/16/19 06:49 PM     Remind Me!  Send Private Message   Edit Post
Got my TV/Radio in and deleted the cigar lighter and put a USB extension in. Also installed shifter bushings and it's solid.
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246498 posted 06/30/19 08:47 PM     Remind Me!  Send Private Message   Edit Post
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246664 posted 07/22/19 09:49 PM     Remind Me!  Send Private Message   Edit Post
Update: Got the radiator fan to work with factory sensors and system and mounted fan.
Reinstalled Hood and put hood bra on.
Checked over headlight, and marker lights
Last on the list is to adjust clutch master
Install Bike rack
Reinstall exhaust
Cut bumper support for intercooler
Cut bumper
Check for leaks while running
Check Boost Controller setup
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246666 posted 07/22/19 09:53 PM     Remind Me!  Send Private Message   Edit Post
565/2000
699/2000
Galant VR-4 org Post #: 1246667 posted 07/23/19 06:45 AM     Remind Me!  Send Private Message   Edit Post
I like the USB fitment. Is that a part designed to install in the lighter slot specifically?
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10768 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246743 posted 07/28/19 09:00 PM     Remind Me!  Send Private Message   Edit Post
Thank you and Yes it is.
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246744 posted 07/28/19 09:35 PM     Remind Me!  Send Private Message   Edit Post
Edited by Terrance362 (07/28/19 09:41 PM)
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246745 posted 07/28/19 09:42 PM     Remind Me!  Send Private Message   Edit Post
565/2000
699/2000
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1246826 posted 08/05/19 07:04 PM     Remind Me!  Send Private Message   Edit Post
Update:
565/2000
699/2000
Pages: 1 | 2
Generated in 0.044 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
