Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » A proper build thread for 1501
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104234 posted 01/22/13 12:00 PM     Remind Me!  Send Private Message   Edit Post
For those of you who don't know me, my name is Craig. I have been the owner of 1501 for about a year now. My brother owned it for about 4 months before me, and my best friend Mark for about a year previous to that. I knew when Mark bought it, it would eventually be mine. My little brother started an introduction thread, which I basically took over and have been using as a build thread. Since the car is back on jack stands again, I decided its time to do things right.
Here is my introduction thread, if anyone wants to check out previous cars and such LIV4PSI newbie intro
Now onto 1501. Its all started about two years ago when my friend Mark listed his Jeep Cherokee for sell/trade on Craigslist. His first offer was for a Galant VR4. Here is the car when he got it. The only mods were an HID headlights, HKS turbo timer, and an improperly installed HKS BOV. At this point we knew we were saving it from a ricer. Here are some shots of the Jeep, and the 1501 when we first got it
The first thing Mark did to it was paint the chrome grill bllack, since we both hated the chrome. In retrospect, I wish I would have talked him into painting it body color. He also gave the car a much need cleaning
When we picked it up, the only known issues were a bad rear wheel bearing and of course the 4WS was leaking everywhere. No surprise there. Within a short time, the first thing broke under our ownership, the oil return line
Mark being overly anxious to start modding (much more maintenance was needed), he started with a 2G downpipe and some wheels I had laying around from a 2000 Sentra I parted out. He kept the stockish look, and painted them Summit White.
Edited by LIV4PSI (07/19/13 12:44 PM)
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (151.213.69.40) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104235 posted 01/22/13 12:01 PM     Remind Me!  Send Private Message   Edit Post
Our next step was to get rid of the horrible stock intercooler setup. I had an old school Apexi hybrid core laying around from an FD I parted out that I let Mark use. I also had alot of random piping and couplers laying around, so we just used what we had for free, and I think it came out decent. Although I wish he wouldn't have cut the bumper in hindsight
We took 1501 to its first DSM/EVO Shootout. The 19th annual
Next came our first round of trying to cure the DSM herpes that it came with.
-Cleaned the engine bay
-replaced cracked 1g exhaust manifold with a ported, sand blasted 2g mani
-shaved and painted the valve cover
-installed EVOIII 16G turbo and tubular O2 housing
-deleted balance shafts
-installed SPEC clutch kit
-AN return line
-lightweight crank pulley
-tried fixing several leaks (failed)
Edited by LIV4PSI (01/22/13 12:59 PM)
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104236 posted 01/22/13 12:02 PM     Remind Me!  Send Private Message   Edit Post
So after the oil pan leaked onto the clutch and ruined the new Spec clutch, I decided it was time to make my move. I got my brother to trade Mark his Miata plus some cash for 1501. My brother owning the car was one step closer to it being mine
Here is a shot of the Miata we traded my friend for it.
My brother's ownership was very short lived. One of the ebrake cables snapped, driveshaft bushings needed replaced, and the water pump belt pulley came off shearing a bolt. That was all he could handle. He sold the VR4 to me, and talked my dad into loaning him the difference to buy another WRX. My brother is, and always will be a Subaru guy. I own an STI, so I can't blame him
The car was basically JSB status when I got it. The pulley needed fixed, the clutch was slipping, still had the bad wheel bearing, and a fuck ton of leaks. I let it sit as I slowly accumulated parts, until it came time that I had to make a decision. I thought I broke the input shaft on my STI, and I had to decide which car got my limited funds. So I foolishly decided to let my Subaru sit, so I could get 1501 ready for the 20th annual DSM Shootout. This was our second round of removing DSM herpes.
-Cometic gasket kit
-Fluidampr pulley to replace the cheap aluminum one (APR hardware as well)
-New SPEC disc since the old one was soaked in oil
-Resurfaced a used ACT lightweight flywheel (ARP hardware)
-New 2G clutch fork and OEM pivot ball
-5 lug swap and 4 bolt rear end from a parts car
-New rims for the 5 lug swap from an FD I had parted out
-Avid mounts since the stock ones were done for
-JNZ clutch line
-ABS delete
-Symborski shift kit with all OEM shifter assembly bushings from JNZ
-OEM rear main seal kit
-Energy Suspension master bushing kit
-New manual steering rack with new OEM bushings from JNZ
-ordered vanity plates since I'm cool like that
We barely got the car together in time for the 20th DSM Shootout. We got the car back together the night before. I ended up using a spare 4 bolt DSM subframe, as we didn't get mine finished with all the spare goodies I bought. The front sway bar wasn't installed. The car had no alignment and a crooked steering wheel. And to top it off, the battery turned into junk while sitting, so we had to take a jump box. I also sliced a tendon in my finger when removing the valve stems because I was rushing. No worries though, it was all worth it.
Edited by LIV4PSI (01/22/13 03:36 PM)
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104237 posted 01/22/13 12:02 PM     Remind Me!  Send Private Message   Edit Post
I started a full build/restoration of my rear subframe and suspension last summer. Everything will be painted with POR, new wheel bearings, endlinks, ball joints etc as well.
The new subframe from a 93 AWD DSM, arriving at my friends shop
All disassembled after some fun with the torches
The old bushings removed and holes cleaned up for..
The new BoostX bushings
New camber arms
The rusty 4 bolt diff before I started cleaning it up
Jay Racing Toe eliminator kit
-Craig
1501 Build Thread
Edited by LIV4PSI (07/19/13 01:05 PM)
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1104243 posted 01/22/13 12:46 PM     Remind Me!  Send Private Message   Edit Post
Looks nice, what size are those sentra wheels?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (50.193.76.5) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104245 posted 01/22/13 12:54 PM     Remind Me!  Send Private Message   Edit Post
Lots more to come by the end of the day. Those pics are still from a year and a half ago, and before I even owned it.
The Sentra rims are 16x6
-Craig
1501 Build Thread
JDM Unit
486/1000
Galant VR-4 org Post #: 1104246 posted 01/22/13 01:03 PM     Remind Me!  Send Private Message   Edit Post
Nice, were they hub centric?
www.nostalgic.co.jp
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104247 posted 01/22/13 01:07 PM     Remind Me!  Send Private Message   Edit Post
Yes. If I remember right, there is a 1mm or so difference from the stock GVR4 wheels. So we did have to machine them ever so slightly.
-Craig
1501 Build Thread
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1104365 posted 01/22/13 08:53 PM     Remind Me!  Send Private Message   Edit Post
Haha I see myself in your 2011 shootout pic =)
2001 R34 Nissan Skyline “Eleanor”
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.83.245) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1104367 posted 01/22/13 08:58 PM     Remind Me!  Send Private Message   Edit Post
Hopefully we will have some more of our cars together in the 2013 Shootout pics
-Craig
1501 Build Thread
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (174.130.206.225) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1104378 posted 01/22/13 09:15 PM     Remind Me!  Send Private Message   Edit Post
Hell yeah, For sure. I can't wait.
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1133126 posted 07/19/13 01:11 PM     Remind Me!  Send Private Message   Edit Post
So 1501 has sadly been sitting since January due to a broken rear brake line. I was forced to switch focuses to my 04 STI, as it is a much better daily driver. I have been accumulating parts for the last few months, hoping to bring a decent car to the Shootout. I decided to not rush it back together like I had to last year, so I am going to hold off on installing alot of my new goodies.
In the next few weeks I will be finishing up my rear end rebuild, rebuilding the driveshaft, and replacing both rear brake lines from the prop valve to the calipers. I already picked up some techna fit SS lines from Bob Dole and installed them. I headed out to the garage now, I will post some updated pics when I come back inside.
-Craig
1501 Build Thread
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (71.30.51.86) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1136043 posted 08/12/13 12:21 AM     Remind Me!  Send Private Message   Edit Post
So I haven't gotten nearly as much done before the Shootout as I had hoped. I did get my driveshaft finished up though. The carrier bearings were causing it to thump pretty bad, especially under deceleration
Here's the DSS aluminum drive shaft beside my stock one
I sanded blasted the rear section and coated it with POR15. I also replaced the carrier bearing, u-joint, and bushings
-Craig
1501 Build Thread
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (66.87.93.93) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1136050 posted 08/12/13 01:17 AM     Remind Me!  Send Private Message   Edit Post
Can't wait to get mine.
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.83.199) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1136525 posted 08/15/13 01:04 PM     Remind Me!  Send Private Message   Edit Post
In retrospect, I have a hard justifying the DSS driveshaft. I am all about efficient HP gains, but I have more money in that driveshaft than I do in my truck I use to tow the VR4
Anyways, I got the driveshaft installed. I also replaced to drive side hard brake line from he prop valve back. Installed some SS brake lines on all four corners while I was at it
-Craig
1501 Build Thread
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (151.213.138.45) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1137015 posted 08/19/13 10:34 PM     Remind Me!  Send Private Message   Edit Post
1501 made it to its 3rd in a row Shootout this year. and it made the trip with minimal issues. I got to drive it to work for the first time today since January, and when I came home my girlfriend was wearing this. Life is good
Only downside is that the Shootout gives me dumb ideas. I keeping thinking I should part out my STi, and spend some real money on my VR4.
-Craig
1501 Build Thread
Olson
Pwnd by Rance.
338/2000
Galant VR-4 org Post #: 1137042 posted 08/20/13 03:20 AM     Remind Me!  Send Private Message   Edit Post
You have boobs? thats kinda weird for a dude....
338/2000
05 TDI Wagon
88 Raider
"Oh, and if you want to build your status and rank, go play some WoW. Come back when you're ready to talk cars". Qship
Posts: 1237 | From: Moreno Valley CA | Member Since: 10/08/06 | IP: (180.131.236.30) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1137045 posted 08/20/13 05:09 AM     Remind Me!  Send Private Message   Edit Post
Quoting LIV4PSI:
I've always suspected that people don't actually read build threads, they just look at pics. Wel I guess this is proof. At least the first reponse wasn't asking me to post noodz
-Craig
1501 Build Thread
Olson
Pwnd by Rance.
338/2000
Galant VR-4 org Post #: 1137048 posted 08/20/13 06:03 AM     Remind Me!  Send Private Message   Edit Post
had to dude.
338/2000
05 TDI Wagon
88 Raider
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1137067 posted 08/20/13 10:49 AM     Remind Me!  Send Private Message   Edit Post
Quoting LIV4PSI:
Now your thinking right! That's what I would do.
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (71.8.42.50) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1141294 posted 09/19/13 05:44 PM     Remind Me!  Send Private Message   Edit Post
So once again, 1501 is jack stand ballin' It's all for a good reason though. I sold my spare 4 bolt rear subframe that I was currently using. I've been making some good progress on getting my refreshed subframe finished.
My plans while it is apart are
1. Undercoat unibody and wheel wells, fix pinch welds
2. New -8an feed, -6an return and new passenger brake line (DS is done)
3. POR fuel tank and sending unit
4. Brand new emergency brake cables
I also acquired another parts car. 1501 has now claimed the rusty souls of 627/200 and 960/1000. New goodies I'm keeping are
-5k mile transmission w/ double synchro 2nd gear, newer T-case
-Omori DIN pod with water temp, oil pressure and boost gauges
-Whiteline front and rear strut bars
-Exedy clutch (mine slips)
-JDM RS replica CF hood with Aerocatch hood pins
-92 grill
- some really nice interior pieces I needed (uncracked dash, perfect console lid)
I also just bought this off of eBay for $100. Ad said it came off of a car with 10k miles, I believe it
Here is a teaser part of some of the parts I've been accumulating
-Craig
1501 Build Thread
Edited by LIV4PSI (09/19/13 09:33 PM)
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (108.162.216.149) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1141386 posted 09/20/13 12:49 PM     Remind Me!  Send Private Message   Edit Post
Look at all they purdy parts there.
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (108.162.221.139) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1145070 posted 10/17/13 11:55 PM     Remind Me!  Send Private Message   Edit Post
I have decided to stay content with 16G power levels, and focus on making my car nice. My best friend and his father own a body shop, and his father has almost 40 years of experience. My friend wants quite a few parts I have, so I decided now is the time to paint it.
Plans are:
-JDM front and rear bumpers
-facelift projector fog lights
-Carbon fiber replica RS hood (painted of course )
-93 headlights/ putting stock corners back on
-92 grill
-wingless trunk
I fucked around and just bought this, so now I'm committed
-Craig
1501 Build Thread
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (173.245.54.103) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1145334 posted 10/20/13 02:10 AM     Remind Me!  Send Private Message   Edit Post
who are you going to buy the replica RS cf hood from? My understanding is that the few that were made were it...
p.s. You can't have mine
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Edited by slugsgomoo (10/20/13 02:11 AM)
Posts: 3711 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (199.27.128.232) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1145372 posted 10/20/13 01:38 PM     Remind Me!  Send Private Message   Edit Post
I already have the RS CF hood, so no need to buy it from anyone
The only thing I still need to buy is the rear bumper. Now if Citymunky would just sell me his
Anyone have any thoughts about me painting it Wicked White?
-Craig
1501 Build Thread
Edited by LIV4PSI (10/20/13 02:00 PM)
Pages: 1 | 2 | 3 | 4 | 5 | 6
Generated in 0.404 seconds in which 0.284 seconds were spent on a total of 14 queries. Turbo powered.
