Corner light removal
veganbutcher
I hope I'm not the only one who doesn't know this, how do you get the corner lights off of these cars? /ubbthreads/images/graemlins/banghead.gif
xaisomboun
Minnesota
Don't worry your'e not alone... Theres a thread on how to remove them and it involves a flathead against the body I think... I was too afraid to try @_@
solidviper89
Mission/ San Antonio, Texas
They have a spring.
When that is removed you can use the screwdriver, gently.
edit: before anyone else says, learn to use the search function
quick search with "+corner +light +remove -re:" yielded a howto post
took me a while to remember how to use the dam search function. /ubbthreads/images/graemlins/cool.gif
raptorWagon
Oak Harbor, WA
Don't even need a flat head, all I did was slide them out enough gently, then unhook the spring to the housing and done, don't forget to twist out the light bulbs as well.
veganbutcher
Where does the spring hook onto the body? Are there any other pieces that I have to take off first. It looks like it's behind the stock air intake.
ktmrider
Tempe, AZ
^^ Did you take the Use the Search function advice below? Thread has pictures BTW...
Quoting solidviper89:
They have a spring.
