shock ???
overboost
worcester ma
I have a question about the front shock if any diffrent left side and right side
and all the mount can i use the right side mount for the left side .
thank you
overboost
worcester ma
i install the new shock and h&r spring but on the passager side the wheel lean out more than dirver side
what did i do wrong
SouthCaliVR4
North county San Diego
where the struts lower bolts just good ol regular bolts or was one of them smaller with a small hump (camber adjustment type)? And did you index the top spring plate with the lower srut housing, They're offset, though I wouldn't think the latter would cause a camber issue. you'll want to align her anyway as lowering of any amount will affect toe settings & you may need camber bolts or you can spring for the upper camber/caster plates.
overboost
worcester ma
what do you mean index the top spring plate with the lower strut housing ??
i dont get it do you have to line them up some how
SouthCaliVR4
On the stock strut the spring is offset in the front. the top spring plate Has a hole to index it with another hole in the lower spring perch. I use a long 1/4 drive extension for the task.
