alansupra94
Well after taking off some electrical tape, I found a slight nightmare. So if someone can, any help would be appreciated. I put clickable thumbnails! I will try my best to get pin-outs asap. From what I am gathering, it looks like a remnants of an ancient SAFC and possible an apex-i turbo timer.
First up is this wire:
Second are these two: I am pretty sure the one with the shielding must be either a knock or 02 sensor.
Anyone have any idea what the white/green wire is?
Third is this one: I got nothing right now
Fourth is this wire wire that is connected to this green/white wire. Doesn't connect anywhere to the ECU harness and doesn't come from the other ECU harness wires, just loose. /ubbthreads/images/graemlins/banghead.gif
Overall view to give you an idea where they are coming from:
Then I look inside of the car and there are home electrical caps being used instead of at least crimps -_-. Fuel pump is done this way too -_-.
My other no-related question is how hard is it to remove the interior driver side fuse box? I want to add a fuse (for my gauges) in the black spot next to the ECS fuse and need to gain access to the back. Or if you have an easier way of gaining access without removing let me know. I know I can just throw a spade crimp connector and use an inline fuse but looks a bit unprofessional.
Thanks,
Alan
Thanks,
Alan
