Need carrier bearings and u joints for ds rebuild
3rdstrikedsm
32159, FL
Are these parts still avl from mitsu? U joints are toast and I may as well replace the carrier bearings while I am there.
If anyone knows what the part #'s are or where to get these parts please advise.
A drive shaft shop want's 900.00 to rebuild the shaft :mad:
14u2nV
Agency/St. Joe, MO
I'm hoping for the same thing,, my carriers are basically hollow. Luckily I have a driveshaft connection for that rebuild. :crazy:
V8EATER
Independence, MO
I bought some from Josh at JNZ about 4 years ago. They were brand new Mitsu parts, and he didn't say that they were hard to get.
dmj
orlando FL
just purchased carrier bearings and u joints from JNZ They are available u can save money by getting 3 transfer case recall kits@ 30.00 each this way u get 3 u-joints for 90.00 instead of 70.00 each.
3rdstrikedsm
32159, FL
Quoting dmj:
What was the cost of the carrier? Also what comes with a t-case recall kit?
004tsi
vancouver, wa
a trans case yoke w/ a u joint,the metal shield thats mounts on the end of the transfer case, and like 8 c clips /ubbthreads/images/graemlins/dunno.gif
turborichvr4
Woodbridge,NJ
The carrier bearing are about $76 at jnz which is not bad you need two of them the u joint are about $70 each one just get 3 transfer recall kits they are about $36 bucks each i just bought mine from JNZ too
dmj
orlando FL
carrier bearings was about 68 to 72.00 each if i remember correctly ihave the invoice in my toolbox somewhere .will post the pn and prices tommorow.
14u2nV
Agency/St. Joe, MO
I have part numbers:
carriers MB505495 - $72/ea @ jnz.. Caps showed me the two are the same number.
u-joints MB154554 - $70/ea @ jnz
3rdstrikedsm
32159, FL
Sweet thanks, So to get this correct I need to ask for a t-case recall kit and it comes with a u-joint and clips all for 30.00? I guess I don't understand how a u joint can be twice as much as the repair kit?
004tsi
vancouver, wa
Quoting 3rdstrikedsm:
Its cheaper because it was a recall so mitsu had to basically "buy" them from their dealers when they preformed the recall, so they don't hardly mark em up like normal parts, you see it with most all recall parts along all car manufacturers
