pot
I’m removing the entire ABS wiring from 182 and am having trouble identifying this connector. This white Connector is located behind the dash above the glovebox and is a 13 Pin Connectors out of 20 possible slots.
I have traced Pin no 28 from the ABS Control Unit (Trunk) to this Connector. The only catch is (182 is a 1992 model year gvr4, and I am using the AWD 1992 ABS wiring schematic) the wire is Green Black (Gb) but the manual says Pin No 28 should be Blue (B) going to the rear right speed sensor.
So in summation: 1) What Connector is pictured 2) What wire is this?
I appreciate anyone taking the time to read this and any help that can be provided. Thank you!
