2.0 litre NA 4G63 fuel injectors, still available?
cheekychimp
East Sussex, U.K.
Galant GTi went in for a service in the UK and the injectors could do with replacing. I've had them cleaned but they still aren't perfect. Local Mitsu dealer says new injectors are NLA. I'm not with the car at present so no opportunity to pull an injector and go parts hunting at an auto parts store.
Can anyone tell me if 2.0 litre NA 4G63 injectors are still available States side and if so are they universal or model specific? I'm sure the GGSX was 2.0 litre NA but I'm not sure if any of the DSMs (Eclipse etc.) were 2.0 litre or 2.4.
Paul.
LIV4PSI
O-H-I-O
Some 1G DSMs came with a NA 4G63. Injectors were 370cc. I don't know if they are still available new, but I guarentee they would work
gvr4ever
central Indiana
Turbo 1G DSM auto US injectors are only 390cc too, so those might we within range as well.
AllanL
NV
the NA injectors were 240+cc, if i remember correctly...
Spyke169
Greenfield, Wi
Have you tried contacting any of the members who have done Galant GSX builds? They may have a set of known good original injectors.
89Mirageman
Stantonsburg, NC
92-95 Hyundai Elantra's with the 1.8 have the same injectors too if that helps. Might be able to find them at a Hyundai dealer, probably cheaper too if so. Or I have several used sets if you want to take a chance.
cheekychimp
East Sussex, U.K.
Quoting ghostinthevr4:
Have you thought about using Honda injectors?
I'll use anything that works! Looks like I'll need to find a shop manual or get in touch with misterfixit to confirm what size the original injectors were.
Quoting Spyke169:
I can try but most of the guys doing GGSX rebuilds go turbo which means that they use larger injectors. Of course they may well still know what size the originals were.
Quoting 89Mirageman:
Great info., thanks!!! I wouldn't mind betting this will be my best bet at finding brand new injectors if I can confirm the size for the GTi injectors is identical.
dandanger
Finland
I can confirm that 4g63 doch n/a used 240 injectors, eg galant gti(edm name for gsx). Can also be found in 4g93 doch (Lancer gti), and 4g67 doch(lancer/colt gti). We got these listed in our Finnish forum.
AllanL
NV
Quoting AllanL:
/ubbthreads/images/graemlins/jawdrop.gif
thanks Dan! /ubbthreads/images/graemlins/applause.gif
cheekychimp
East Sussex, U.K.
Excellent Dan, thank you.
Can anyone with CAPS confirm if these are still available then?
G
zompton
Available from mits? Send me the part #.
kama1
q.c. philippines
Down here,2.0 dohc models has 240cc,2.0 sohc has 210cc the amg has 275cc same with the later rvr.
AllanL
NV
Quoting G:
MD127069 - 88~90
MD158850 - 90~92
for the E33A Galant [SNGML chassis code] and the D22 Eclipse [MNHML4M/9M chassis code]
hth
G
zompton
Yes both are available from Jp.
cheekychimp
East Sussex, U.K.
Awesome guys! I'll check those parts out with the Mitsu dealer here and see if I can order a couple of sets.
Paul.
slugsgomoo
Tacoma, WA
Might check Amazon. My mom has a Toyota that needed injectors and I got them for 20% as much as the dealer wanted...
G
zompton
misterfixit
Midlands, UK
Hi Paul,
Here is the injector data I have collated from around the place (still some gaps) But should help source out some newer ones.
There are basically three generations of each injector (I guess nikki have improved/cost benefited each design over the years.) the basic frame size is interchangable on the series too. so you could source out a later set to the same spec as yours.
Yours is an '88/89 so I guess it'll have the early (first gen) injectors.
Two basic failure modes for the injectors.
1/coil goes open loop/short. (breakdown due to age of insulation. Dupont kapton is usually used as coil insulation, it's now pretty much banned in aircraft use as its not good with heat and time (not a good combination in A/C hydraulics...) Anyway back on topic...
2/ Nozzle shield breaks down (comes apart). i saw this on a Philippine GTI I was working on about 6 months ago.
Hope the list helps you out.
Rich
cheekychimp
East Sussex, U.K.
Okay, so now I am totally confused.
I am assumming that since "G" posted both those eBay links before Rich made his post that the MD127069 and MD158850 are the correct part numbers for injectors to my car. However I tried putting 1988 Mitsubishi Galant into the drop down table in both auctions and it comes back saying these injectors are not compatible. I admit, ebay isn't the most reliable source of information, but I just want to be sure, Rich and G would I be safe ordering either of those injector sets for the GTi?
Paul.
