Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Anyone using this Aluminum Radiator?
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1007394 posted 07/25/11 03:22 PM     Remind Me!  Send Private Message   Edit Post
Hey is anyone currently using this ebay radiator? click If you are using it, how are you coolant temps while daily driving? I seen it mentioned in the end of another thread, but no one said if they were actually using it. My coolant temps were in the 220* area just idling in 90* weather so I think I'm going to change some things up. Thanks
796/2000 Summit White
628/1000 Summit White
91 Black Cherry Talon Auto AWD
94 Pearl White 3KGT
88 Fiji Blue Conquest TSi
03 Labrador Black Evo
Posts: 372 | From: Ferndale, WA | Member Since: 03/23/08 | IP: (206.126.16.82) | Report this post to a Moderator
spooling92vr4
Yeah Toast! * Now with JELLY!!!
829/1000
Galant VR-4 org Post #: 1007397 posted 07/25/11 03:55 PM     Remind Me!  Send Private Message   Edit Post
There is a guy that did a write up on these radiators in the how to section.. I would suggest shooting him a pm and ask him what his temps are.
92 vr4 belize green # 829/1000....NOW RUNS! still needs tuning
Posts: 2511 | From: long island, NY | Member Since: 06/07/05 | IP: (108.41.157.244) | Report this post to a Moderator
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1007402 posted 07/25/11 04:07 PM     Remind Me!  Send Private Message   Edit Post
On this specific one? I looked through a thread about aluminum radiators and I believe they were using a different one, or atleast purchased theirs from someone different. At the end of the thread someone links to the radiator that I'm looking at now to see if its any good, but their were no responses. Heres the other thread click
94 Pearl White 3KGT
broxma
retard monkey strength
379/1000
Galant VR-4 org Post #: 1007403 posted 07/25/11 04:12 PM     Remind Me!  Send Private Message   Edit Post
I use one that is even cheaper. I think I paid 129 shipped for mine off Ebay. I live in Heatstink, Texas. When hell cools off, the demons and minions come here to warm up. My car drives in the blazing sun like a beast, and never goes north of 215ish. Paying 500.00 for a radiator is silly to me. It's akin to saying, which 3 inch pipe will flow the best, the one from ETS or Buschur?
That being said, you could get screwed but who cares, it's 129 dollars.
/brox
I am big into recycling though and if your not into sacrifice or burnt offerings, you may want to stick with 93 octane.
/brox
Posts: 911 | From: San Antonio Tx | Member Since: 11/16/09 | IP: (99.52.72.193) | Report this post to a Moderator
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1007409 posted 07/25/11 04:42 PM     Remind Me!  Send Private Message   Edit Post
Hmmm, this was the only one that I found for the GVR4 on ebay right now that is all aluminum. Any tips on finding the $129 one?
94 Pearl White 3KGT
4doorboost
827/2000
Galant VR-4 org Post #: 1007412 posted 07/25/11 04:58 PM     Remind Me!  Send Private Message   Edit Post
i use one and my car runs super cold all day. i dont know exact temp but the gauge never even sees half way (straight up and down) even on a super hot day
Posts: 208 | From: Westlake Village, Cali | Member Since: 08/19/08 | IP: (171.159.64.10) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1007414 posted 07/25/11 05:02 PM     Remind Me!  Send Private Message   Edit Post
This is what I bought.
You need to get a 1G t-stat water neck.
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.27.92.172) | Report this post to a Moderator
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1007416 posted 07/25/11 05:10 PM     Remind Me!  Send Private Message   Edit Post
How does that one work for you Terry temperature wise? How long have you had it? Any signs of leaking and what kind of temps do you see? I see its a realy good price shipped, especially with fans, so it makes me a little skeptical. Also, do both fans fit? The poor slimfan(poor because of airflow, not depth) that I have would just barely barely fit on the drivers side, and the core on my current oem replacement is tiny.
94 Pearl White 3KGT
Old Balls
425/1000
Galant VR-4 org Post #: 1007424 posted 07/25/11 05:34 PM     Remind Me!  Send Private Message   Edit Post
It works good for me. One fan is pulling and one is pushing. With a 160 t-stat and a custom 140 thermo switch, I see temps 160 to 180 temps. I have only seen 190 once and that was on the dyno pulling 361whp.
It would be better if you can use proper shrouded fans but works for me.
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1007436 posted 07/25/11 06:21 PM     Remind Me!  Send Private Message   Edit Post
Perfect, I'm going to use that one then. Hopefully I can make the driver side fan fit one way or the other. I am on the edge of ditching my A/C, so I still have the pusher hooked up on the condenser and I'm about to wire it to a toggle switch or permanetly on with the ignition.
94 Pearl White 3KGT
Nabeel
Member +
Galant VR-4 org Post #: 1007440 posted 07/25/11 06:49 PM     Remind Me!  Send Private Message   Edit Post
I am using ebay one for 1g. I think brand name is CRX. I bought one with fan & fan shroud. I did not used the fans. I bought 1g fan & 1g thermostat housing. It works good. Just buy radiator without fans. there fans are not enough & just wast of money.
91 VR4
09 GT eclipse
91 Cefiro
Posts: 257 | From: K.S.A | Member Since: 07/14/06 | IP: (77.30.82.171) | Report this post to a Moderator
Vman911
Member +
1667/2000
Galant VR-4 org Post #: 1007445 posted 07/25/11 07:16 PM     Remind Me!  Send Private Message   Edit Post
I did the write up in how to sect to install that radiator.
I'm using the same one from china. I currently have a 180 degree thermostat in the car. I just returned from a 900 mile trip in 1667/2000. Temps stay at 180 while cruzing down hwy. (got 23MPG) now when in town and stop and go traffic temps creep up to 210+ until car moves again. (something is up with my thermo switch) Its 94+ degrees in atlanta. I'll let you know what it runs when it cools outside.
Vinman
Edited by Vman911 (07/25/11 07:18 PM)
Posts: 358 | From: Douglas county, Ga | Member Since: 09/18/05 | IP: (72.148.214.106) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1007653 posted 07/26/11 07:09 PM     Remind Me!  Send Private Message   Edit Post
Quoting broxma:
/brox
LMAO I like how you described tx haha thats where im from, houston in perticular
2001 R34 Nissan Skyline “Eleanor”
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (24.249.34.170) | Report this post to a Moderator
broxma
379/1000
Galant VR-4 org Post #: 1007715 posted 07/26/11 11:06 PM     Remind Me!  Send Private Message   Edit Post
Mine is a 1G with a fill on the water neck. When you factor in the 5 dollar cost of the water neck at the boneyard and the 99-129 dollar price of the CX racing or whatever Radiator, it's hard to beat. Mine was even a multi core radiator, whatever the hell that means.
/brox
/brox
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1007736 posted 07/27/11 02:09 AM     Remind Me!  Send Private Message   Edit Post
Well my buddy is giving me back the 1g Fluidyne radiator that I gave him a couple years ago when I sold my talon. Hopefully that will do the trick for me. I'm a little concerned on if it will fit. Its really thick and I already have a tight fit between my tial 38mm on the top of the manifold, the intercooler piping, and the stock radiator. Also my dump tube is close to touching the fins on my stock radiator. Hopefully it fits, the fluidyne is expensive so it would be nice to not let it go to waste.
94 Pearl White 3KGT
Posts: 372 | From: Ferndale, WA | Member Since: 03/23/08 | IP: (68.186.77.187) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1007773 posted 07/27/11 10:56 AM     Remind Me!  Send Private Message   Edit Post
Quoting Terry Posten:
Terry, where did you get the 140 thermo switch from?
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1007832 posted 07/27/11 04:59 PM     Remind Me!  Send Private Message   Edit Post
It is an A/C thermo adjustable switch from Grainger It is selectable from 140-180 turn on and it turns off 20 degrees colder than the set point. And it was less than $20.00.
It does not screw in, it is mounted flush to the core with straps.
It wires just like the stock thermo switch. 2 male spade terminals. Normally open until temp set point is reached.
Very simple. And works very well.
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 1008108 posted 07/28/11 11:28 PM     Remind Me!  Send Private Message   Edit Post
Here is a link to the AFCO Scriocco aluminum radiator, yes it's a bit more costly, and their are no fans included. However, I've had many friends run these, as well as a bunch of folks here on the board. Superb quality, perfect fitament, even with different WG locations, as well as I/C pipe placement. I have only heard great things about it and can't wait to have mine running, I just need to build mounts for my fans.
Check this link for some alternative info AFCO radiator
EDIT: AFCO Radiator
SteveW
484/1000 Kensington Grey - Running VERY well :-)
564/2000 Belize Green ~ SOLD
749/2000 Summit White ~ SOLD
1989 Chrysler Conquest TSi SHP ~ SOLD
2004 Saab 9-5 ARC ~ Daily Driver
Edited by mistaVR4 (07/28/11 11:35 PM)
Posts: 4768 | From: Boulder, CO | Member Since: 12/16/03 | IP: (76.120.73.89) | Report this post to a Moderator
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 1008145 posted 07/29/11 09:57 AM     Remind Me!  Send Private Message   Edit Post
I think its time that we demand mods to make DIY or we can vote to remove their mod status That is actually an excellent setup Terry.
I can tell you from experience from both the industrial and automotive industry, the fin design and quality of a radiator will dictate how well it will perform. Radiators and intercoolers are one of the few parts that I actually spend quite a bit of money on to make sure I get quality.
1992 Galant VR4
1996 Toyota Supra TT
Edited by alansupra94 (07/29/11 11:18 AM)
Posts: 1909 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (192.132.229.1) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1008161 posted 07/29/11 10:59 AM     Remind Me!  Send Private Message   Edit Post
Mounted with straps? It won't leak? Any pics? I am very interested in doing this.
92 GVR4 #802 link
SOLD: 92 GVR4 #611
1 registered and 40 anonymous users are browsing this forum.
Generated in 0.179 seconds in which 0.129 seconds were spent on a total of 14 queries. Turbo powered.
