Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Rear differential leak
GVR4ZUM
734/2000
Galant VR-4 org Post #: 832030 posted 09/21/09 03:42 PM     Remind Me!  Send Private Message   Edit Post
My rear diff started leaking. How hard is it to replace the seal?
Can it be done by disconnecting the driveshaft and taking out that one nut, go through it that way?
Please excuse the phone pic.
Aufrecht Melcher Grossaspach
734/2000
Posts: 1447 | From: SoCal, USA | Member Since: 07/08/02 | IP: (66.252.189.74) | Report this post to a Moderator
Galant VR-4 org Post #: 832041 posted 09/21/09 04:32 PM     Remind Me!  Send Private Message   Edit Post
Yes, you can by pulling off the companion flange.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10772 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
1941Galant
Will fight mice for food
1941/2000
Galant VR-4 org Post #: 832048 posted 09/21/09 04:52 PM     Remind Me!  Send Private Message   Edit Post
Is there any thing special you have to do when tightening down the pinion nut, or just torque to spec and be on your way?
Posts: 1904 | From: Charles Town, WV | Member Since: 08/21/04 | IP: (70.44.252.218) | Report this post to a Moderator
Galant VR-4 org Post #: 832073 posted 09/21/09 06:16 PM     Remind Me!  Send Private Message   Edit Post
If you have not displaced the pinion shaft at all, should be ok. May be a trick holding it to torque it though.
Posts: 10772 | From: Michigan | Member Since: 03/05/01 | IP: (74.36.90.79) | Report this post to a Moderator
1941Galant
1941/2000
Galant VR-4 org Post #: 832076 posted 09/21/09 06:30 PM     Remind Me!  Send Private Message   Edit Post
Alright, thanks.
Senior Ricer
1552/2000
Galant VR-4 org Post #: 832090 posted 09/21/09 07:22 PM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
E-brake ftw?
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.62.73) | Report this post to a Moderator
Galant VR-4 org Post #: 832272 posted 09/22/09 08:37 AM     Remind Me!  Send Private Message   Edit Post
Hmmm, maybe.
715/1000
1284/2000
Galant VR-4 org Post #: 832278 posted 09/22/09 08:47 AM     Remind Me!  Send Private Message   Edit Post
You can always use spare bolts and put them in the holes and wedge a bar between the bolts to hold the flange still while tightening the nut.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (24.220.12.198) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 832311 posted 09/22/09 10:35 AM     Remind Me!  Send Private Message   Edit Post
I got a lot of practice at this job when I was building v-8 z cars back in the day...
One trick I learned from a saavy old gear vendor was to was to make some witness marks from the shaft to the flange to the nut with a touch up paint pen before you take it apart.
If you're re-using the nut, not recommended!, (but often done with copious quantities of the correct grade of loc tite... ) and you clock the flange back on the shaft in the same location, when the line on the nut aligns with the witness marks on the shaft and flange, you're in the ballpark torque-wise. This is handy when the diff is out of the car and you don't have an easy way to hold the pinion to torque it correctly. To do this job correctly, you can make a fixture that bolts the companion flange fairly easily, but it still looks like monkey's fucking a football as you chase the thing around the bench... (these pumpkins are easy compared to many I've done in the past!)
Remember, you're setting the preload on the bearings when you torque the flange nut down. Take your time and do it right!
It usually works out just fine if you end up a red curly hair tighter than the original witness mark, but your mileage will vary.
Since you have the car there, you can do it the easy way and just replace the seal without dissassembling anything else.
Pop the driveshaft flange off, support the driveshaft with a couple of bungy out of the way.
Set the e-brake firmly
Mark everything, and using hand tools =socket and breaker bar=, remove the nut (**cheater bars allowed if you're a Nancy boy, just don't blast it with an impact!**)
Slide the flange off, and inspect the sealing surface. Deep grooves/ugliness means a wtb add.
Using a small, sharp awl (or a nail ) poke a hole in the seal face, more towards the outside edge.
Thread a small sheetmetal screw into that hole. The bearing is only about 1/4" back, so don't go crazy screwing the damn thing in.
Gripple onto the head of the screw with some vice grips, and lever/pull the seal out.
You can also use a t handled seal puller, or a screwdriver/prybar, but I like ^^this^^ way the best, becasue you won't scratch/damage either the flange or the case.
For best results, clean the sealing surface on the companion flange with soft scotchbrite. If it is grooved a little where the previous seal cut into it, be sure to get a seal with a different following letter prefix. (the seal manufacturers are fairly saavy, and they change the location of the sealing lip a schosche, and identify those seals with a higher following letter. I.E. 1773c versus 1773a )
Do not spray any cleaner into the front case/pinion bearing recess, as it will contaminate the front bearing. Just wipe clean with a lint free towell.
With all the halfshafts still installed, just install a new seal (after throwing a little assembly lube/grease on the sealing lip ), spin down a new lock nut with hand tools, lock the handbrake, and slowly sneak up on the middle of the torque range.
The factory spec is 116 to 159 ftlb's
Fill the diff with your favorite flavor gear oil.
Done
**For those with access to power tools, don't attack the pinion nut with an with an impact gun if you don't want to see what pinion bearings look like.
The whackity whack whack of an impact will brinell the ever loving dog shit out of the pinion bearing races and the bearing races will begin to deteriorate shortly thereafter...
Posts: 3540 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.14.47) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 832313 posted 09/22/09 10:41 AM     Remind Me!  Send Private Message   Edit Post
... I need to make a whole new archive section just for John's posts.
Ryan Hertz
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
GVR4ZUM
734/2000
Galant VR-4 org Post #: 832480 posted 09/22/09 07:58 PM     Remind Me!  Send Private Message   Edit Post
^^^ I like it when John responds like that, very detailed.
Thanks guys.
734/2000
Posts: 1447 | From: SoCal, USA | Member Since: 07/08/02 | IP: (173.70.119.133) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 832646 posted 09/23/09 10:08 AM     Remind Me!  Send Private Message   Edit Post
especially for us nancy boys...
12yr+ Vr4 owner.
Family Guy
Gray Monster
Galant VR-4 org Post #: 834510 posted 09/28/09 09:28 PM     Remind Me!  Send Private Message   Edit Post
My rear end started leaking a couple of weeks ago also. I finally got a chance to replace the seal this weekend. That nut was tough. I spent a good half day just removing it. I tried the hand brake at first and I didn't like how the force was not being applied directly to the nut. There was still play as I would torque the breaker bar to try loosen the nut. Below is how I did it using the info as was posted above by Mr Toybreaker.
1. I went to Lowes and purchased a 1/4 inch thick steel bar.
2. Drill 2 holes to secure the bar to the flange. Use the holes that are 2 inches apart.
3. Tighten the steel bar with the two bolts onto the flange. The bar will brace against the subframe as you apply force to the nut.
**After you install the new seal, simply reverse the bar in the opposite direction to torque the new nut.
4. Remove the seal. I used the lever/pry aprroach. It popped completly out on the 3rd try. Be careful with any sharp edges and keep the internals clean. DO NOT drill; you want to poke it to start the hole for the sheet metal type screw.
5. Carefully install the new seal and torque the nut back on.
6. Fill back up with your favorite GL-5 gear oil. (.7 liter = .74 quart)
Differential Pinion Seal part number = MB393929 = BCA/Nationl 471847N (it was around $7 or $8)
Good Luck and be Safe!!
Posts: 66 | From: San Marcos,Texas | Member Since: 10/18/03 | IP: (76.203.197.29) | Report this post to a Moderator
GVR4ZUM
734/2000
Galant VR-4 org Post #: 834636 posted 09/29/09 08:43 AM     Remind Me!  Send Private Message   Edit Post
Nice, thanks for responding to this post and taking the time to take some pics.
Mods, maybe you can add this to How To so others can benefit from it as well.
Thank you.
734/2000
715/1000
1284/2000
Galant VR-4 org Post #: 834641 posted 09/29/09 09:11 AM     Remind Me!  Send Private Message   Edit Post
^1 on that, great tip. Looks like I'm building a new speciality "tool".
12yr+ Vr4 owner.
Family Guy
Generated in 0.055 seconds in which 0.025 seconds were spent on a total of 14 queries. Turbo powered.
