Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » timing connector pic?
gmp
56 pounds
213/1000
179/2000
Galant VR-4 org Post #: 681214 posted 08/13/08 03:12 PM     Remind Me!  Send Private Message   Edit Post
i was wondering if some one could send me a pic of the ignition-timing connector this pic doesn't really help to much,also which side of the connector would i need to ground to trick the computer so i can do base timing?
(213of1k) Sold then died.
(179of2k) back in black
Make Old New Again
Posts: 549 | From: Denver,co | Member Since: 04/01/07 | IP: (67.190.162.49) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 681229 posted 08/13/08 03:35 PM     Remind Me!  Send Private Message   Edit Post
That pic doesn't help? It has a big stick pointing right at the connector.
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 681230 posted 08/13/08 03:35 PM     Remind Me!  Send Private Message   Edit Post
It is the connector pictured left of your slave cylinder resevoir.
182/1000
Posts: 1548 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (204.34.247.9) | Report this post to a Moderator
gmp
56 pounds
213/1000
179/2000
Galant VR-4 org Post #: 681234 posted 08/13/08 03:36 PM     Remind Me!  Send Private Message   Edit Post
well i don't have the plug there just wire the plug is missing from one of the previous owners so thats my reasoning for the color of wire and which one needs to be grounded.
Make Old New Again
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 681276 posted 08/13/08 04:41 PM     Remind Me!  Send Private Message   Edit Post
the way I remember it is "thumb-shaped". Your thumb should fit almost perfectly over it. Plus there's only one connector in there. I suck at spotting it visually on a jpg
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
gmp
56 pounds
213/1000
179/2000
Galant VR-4 org Post #: 681339 posted 08/13/08 07:07 PM     Remind Me!  Send Private Message   Edit Post
well i would do the thumb thing but i dont have the plug just wires so anyone know the colors and which one i need to ground?
Make Old New Again
Galant VR-4 org Post #: 681429 posted 08/13/08 11:04 PM     Remind Me!  Send Private Message   Edit Post
There is only one wire in that connector and it is yellow w/ red stripe.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10835 | From: Michigan | Member Since: 03/05/01 | IP: (65.73.152.25) | Report this post to a Moderator
gmp
56 pounds
213/1000
179/2000
Galant VR-4 org Post #: 681492 posted 08/14/08 02:16 AM     Remind Me!  Send Private Message   Edit Post
sweet thanks alot,thats the answer i was lookin for all day haha
Make Old New Again
mr.mitsu
Member +++
Galant VR-4 org Post #: 807628 posted 07/03/09 08:38 AM     Remind Me!  Send Private Message   Edit Post
Is this the same plug?
It is yellow with a green main stripe and red little stripes.
When I grounded this and started the car I blew my 30A fuse for the ignition.
Posts: 798 | From: canada | Member Since: 04/28/03 | IP: (99.227.254.145) | Report this post to a Moderator
GVR4_1057
Member ++
1057/2000
1604/2000
Galant VR-4 org Post #: 807636 posted 07/03/09 09:18 AM     Remind Me!  Send Private Message   Edit Post
That is the fuel pump test wire. It allows you to test the fp relay or if you put 12 volts on it you can bypass the fp relay and the fuel pump will turn on.
Billy B,
1057 Back after 5 years JSB
1604 all fixed again.
1986 Audi 4KQ
1997 BMW E36 328I
Posts: 676 | From: Brucetown VA | Member Since: 09/03/08 | IP: (24.127.96.37) | Report this post to a Moderator
mr.mitsu
Member +++
Galant VR-4 org Post #: 807651 posted 07/03/09 10:09 AM     Remind Me!  Send Private Message   Edit Post
I can't find this plug for the life of me!
Can anyone provide a pic of the actual connector?
Key Fob Guy
Galant VR-4 org Post #: 807655 posted 07/03/09 10:27 AM     Remind Me!  Send Private Message   Edit Post
Holy crap! Look at the pic in the first post. There is a huge black rod () pointing right at the connector! (The lower one)
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (71.1.56.15) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 807979 posted 07/04/09 03:53 PM     Remind Me!  Send Private Message   Edit Post
This is the connector, circled in red:
It is almost oval shaped, with room for 2 pins in it, but there is only one small pin inside when you remove the dust cover.
| | | IP: (74.163.255.175) | Report this post to a Moderator
ItsAliiive
Galant VR-4 org Post #: 808002 posted 07/04/09 05:00 PM     Remind Me!  Send Private Message   Edit Post
Hi, I'm right here!
| | | IP: (68.2.31.236) | Report this post to a Moderator
mr.mitsu
Member +++
Galant VR-4 org Post #: 808031 posted 07/04/09 08:49 PM     Remind Me!  Send Private Message   Edit Post
OMFG...with closer inspection I found the culprit hiding within the loom
Since this thread is already resurrected here's my next question:
I ground the terminal set the idle to 750 (+/-50) all's good. Then when I disconnect it, the rpm's shoot up to 1200-1300rpm.
BTW, ISC, FIAV and EGR all removed.
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 808722 posted 07/07/09 04:49 PM     Remind Me!  Send Private Message   Edit Post
I could be wrong, but I'm pretty sure you're following the procedure to set the BASE TIMING, not idle. I'm sure you will find the answer if you search some, but I believe you need to also ground the diagnostic port for the idle setting.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
mr.mitsu
Member +++
Galant VR-4 org Post #: 808765 posted 07/07/09 08:06 PM     Remind Me!  Send Private Message   Edit Post
Since this is a How-To:
Ground engine plug + #10 pin (plug in logger)=base idle
Ground engine plug =base timing
Telecaster
1581/2000
Galant VR-4 org Post #: 808888 posted 07/08/09 09:49 AM     Remind Me!  Send Private Message   Edit Post
You have to ground both the timing connector and the pin on the diagnostic port for idle.
Posts: 573 | From: San Jose, CA or Philippines | Member Since: 02/26/02 | IP: (203.87.234.74) | Report this post to a Moderator
Generated in 0.039 seconds in which 0.019 seconds were spent on a total of 14 queries. Turbo powered.
