Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » 89 center tailight section?
Wilfongtsi
Bearded One
Galant VR-4 org Post #: 459064 posted 04/02/07 11:58 AM     Remind Me!  Send Private Message   Edit Post
Will the 89 center taillight section fit on the 91, 92 trunks? I've heard they won't, just tryin to find out for sure. I think they also don't have lights in them or sunthin?
1991 VR4 #1061 (main project)
1987 Conquest TSi (my first car)
2003 Honda RC51 Harley guys hate me!
2000 Silverado ridin on 38's
2000 Honda Insight 70 mpg's!
1998 1LE Camaro
Posts: 444 | From: Fort Wayne IN | Member Since: 05/21/06 | IP: (69.246.195.75) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 459075 posted 04/02/07 12:16 PM     Remind Me!  Send Private Message   Edit Post
He's asking about the unit I've got for sale:
The body is the same (base Galant vs GVR4) so I don't see why they wouldn't bolt right on exactly the same as the stock center section...
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.129) | Report this post to a Moderator
crankwalk
Galant VR-4 org Post #: 459080 posted 04/02/07 12:24 PM     Remind Me!  Send Private Message   Edit Post
It fits but will look like shit without the other two sides.
The sections wouldnt line up at all.
^BTW Cy your picture has the section upside down.
Edited by crankwalk (04/02/07 12:24 PM)
| | | IP: (24.98.140.85) | Report this post to a Moderator
Wilfongtsi
Bearded One
Galant VR-4 org Post #: 459081 posted 04/02/07 12:24 PM     Remind Me!  Send Private Message   Edit Post
Thanks for adding pic. I just like the way the clear part matches the color on the taillights, and I'm going for a badgeless look so no vr4 emblem.
1998 1LE Camaro
Wilfongtsi
Bearded One
Galant VR-4 org Post #: 459082 posted 04/02/07 12:26 PM     Remind Me!  Send Private Message   Edit Post
So its upside down in the pic then, I see.
1998 1LE Camaro
Galant VR-4 org Post #: 459089 posted 04/02/07 12:37 PM     Remind Me!  Send Private Message   Edit Post
I'm pretty sure they are different. I have an 89 center section and a 91 spare center, and the mounting studs are not all in identical locations. They can maybe be moved/removed, so it may fit, but not mount exactly the same.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10770 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
crankwalk
Galant VR-4 org Post #: 459094 posted 04/02/07 12:43 PM     Remind Me!  Send Private Message   Edit Post
^Ok I posted a picture of my car, which is a 91 with 89 tails for reason. It fits!
You dont use all the nut on the back side but other than that it works fine.
Senior Ricer
1552/2000
Galant VR-4 org Post #: 459268 posted 04/02/07 06:47 PM     Remind Me!  Send Private Message   Edit Post
When I did mine I had to open two mounting holes in the trunk way up to make it fit.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (70.107.40.78) | Report this post to a Moderator
crankwalk
Galant VR-4 org Post #: 459274 posted 04/02/07 06:58 PM     Remind Me!  Send Private Message   Edit Post
I didnt do anything and it bolted in.
| | | IP: (171.161.160.10) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 459284 posted 04/02/07 07:12 PM     Remind Me!  Send Private Message   Edit Post
Mine bolted in but the ends wouldn't sit flush on the top. It stuck out about 1/4".
John
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 459302 posted 04/02/07 07:36 PM     Remind Me!  Send Private Message   Edit Post
I went to install a set of these, myself, found the center section doesn't light up, and then realized I wasted $40 buying them. :P I got them because I like the way the amber turn signals are on the top - like on my Talon. Some day, I might even snag a grille from an Eagle Summit and swap it in the front just for shits and giggles...
Brian | 98 Pajero | Gearbox Magazine
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (63.230.251.39) | Report this post to a Moderator
mmc_gsx
Galant VR-4 org Post #: 459390 posted 04/02/07 10:28 PM     Remind Me!  Send Private Message   Edit Post
Will the summit grill will fit the galant? may be 2000gtx will be exact fit.
3 Stars and a Sun. 91Eagle 2000GTX AWD, 90 Eagle Talon TSI AWD, 89 Dodge Colt GT 4g61t with busted frame.
Posts: 192 | From: Edmonton, AB. Canada | Member Since: 03/24/07 | IP: (68.151.37.191) | Report this post to a Moderator
wowzer
Master Mechanic-Will Travel
Galant VR-4 org Post #: 459628 posted 04/03/07 02:24 PM     Remind Me!  Send Private Message   Edit Post
2000GTX is an exact fit Summit is different.
You should be able to switch tails.
Posts: 1719 | From: CS, IL | Member Since: 01/15/07 | IP: (64.109.169.3) | Report this post to a Moderator
Wilfongtsi
Bearded One
Galant VR-4 org Post #: 459829 posted 04/04/07 01:29 AM     Remind Me!  Send Private Message   Edit Post
Did the 91 vr4's center section say vr4 on them? Do they light up?
1998 1LE Camaro
CP
Galant VR-4 org Post #: 459880 posted 04/04/07 07:32 AM     Remind Me!  Send Private Message   Edit Post
No.
-Cy
Polish
Dr. Pilosh Haagenscodyberger
Galant VR-4 org Post #: 459941 posted 04/04/07 09:50 AM     Remind Me!  Send Private Message   Edit Post
My center section lights up on my 91 but has no badge, it's on the trunk lid.
My car site
Old GVR4 #1186/2000
Posts: 8936 | From: NE, IN | Member Since: 01/10/05 | IP: (69.245.199.104) | Report this post to a Moderator
Galant VR-4 org Post #: 459946 posted 04/04/07 10:02 AM     Remind Me!  Send Private Message   Edit Post
Right. Has lights, no badge.
CP
Galant VR-4 org Post #: 459974 posted 04/04/07 10:50 AM     Remind Me!  Send Private Message   Edit Post
Oh that's right, I pulled the bulbs out of my center section taillights. I thought it looked ghey with all that red back there. I was thinking about wiring up a really bright bulb on one side of the center section with a manual switch to be used as a rear foglight, ala Saab, Audi, Volvo.
I also misted some dark spray paint on my license plate bulbs so it doesn't have sun-like beacons illuminating it.
-Cy
misterfixit
Victory Runner
Galant VR-4 org Post #: 460569 posted 04/05/07 04:10 PM     Remind Me!  Send Private Message   Edit Post
Two different shape decklids. definately
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1553 | From: Midlands, UK | Member Since: 08/04/04 | IP: (83.67.97.128) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 460580 posted 04/05/07 04:27 PM     Remind Me!  Send Private Message   Edit Post
I had a wingless 90 decklid and i put my 91 tail light center section in it without any issues. So as far as i can tell they're interchangable.
-Joshua Adventure Driven Design
1991 Galant VR-4
1999 Montero "Goldi-Locker"
Posts: 5593 | From: Arizona | Member Since: 05/28/03 | IP: (67.177.179.249) | Report this post to a Moderator
crankwalk
Galant VR-4 org Post #: 460641 posted 04/05/07 07:05 PM     Remind Me!  Send Private Message   Edit Post
Rich
This thread pisses me off.
Its in your head. I put 89 tails on my 91 with no problem. i now have 93 taillights in with no problem.
I have A PICTURE of my 91 with 89 tails IN THIS THREAD. This isnt science, they just screw in.
Edited by crankwalk (04/05/07 07:07 PM)
IslandVr4
Galant VR-4 org Post #: 460655 posted 04/05/07 08:26 PM     Remind Me!  Send Private Message   Edit Post
^^^What the man said!
| | | IP: (69.29.205.127) | Report this post to a Moderator
rheckert
I Love Wagons
Galant VR-4 org Post #: 460673 posted 04/05/07 09:24 PM     Remind Me!  Send Private Message   Edit Post
I loved that about my volvo till I got pulled over for faulty equiptment.
89 tails fit. Hertz has them as well if I recall.
Family hauler -Yes it has a locking diff.
AWD goodness with 4 doors
Posts: 4115 | From: Indianola, Iowa | Member Since: 03/04/04 | IP: (70.56.13.242) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 460814 posted 04/06/07 09:15 AM     Remind Me!  Send Private Message   Edit Post
To substantiate-------
89 decklid:
89up decklid:
No it's definately not science.
Mouthy C*unts p*ss me off.
Rich
Rich
93 CB4A --- rewound
Stuff Index
Senior Ricer
1552/2000
Galant VR-4 org Post #: 460815 posted 04/06/07 09:16 AM     Remind Me!  Send Private Message   Edit Post
Ummmmmm. No. It's not in anyone's "head". I can't tell you a specific year break but there is a slight difference in the sheet metal of the trunk lid that is underneath the center section of the tail lights. If you'd like a picture of the modifications I needed to make in order to have the center part sit flush on the trunk/tail light combo I'm using then I'll be happy to take one for you so you can see it. Here is a break down of the different trunk lids straight from CAPS:
E33A:
8801.1 - 9005.3 = MB549999
9006.1 - 9302.3 = MB835143
(the break on the tail lights is the same dates )
E39A:
ALL = MB835143
There was certainly a difference of some sort and the fact that the date breaks for the tails were the same as those for the different trunks I'd have to say that the reason the trunks were different was that the tails were different.
Oh, and yes I don't have anything better to do today since its my day off.
John
Pages: 1 | 2
Generated in 0.147 seconds in which 0.068 seconds were spent on a total of 14 queries. Turbo powered.
