Looking for a rear diff housing with 5sp gears differential not important or needed. Anyone got a cheap 1g non lsd rear end no axles needed that I can get for cheap?
Without 4ws thats long gone. Basicly this is so I can put a clutch type lsd in as a quick and easy as a remove and replace job same day. unless there is a shim kit I can buy before hand so I dont have to run the risk of having to wait to determine what/if i need shims and then order them. my general luck says I will need to as or subtract shims
