Whats this connection behind the thermostat housing? Pic
stealthtt24
Orlando, FL
I found this unplugged then noticed the male end behind the thermostat housing. Plugged it I'm but can't start the car till rtv cures. What is it?
desant78
Clarksboro, NJ
I really can't tell what is in your picture confidently. I do know that the coolant temp for your dash is a sensor in the t-stat housing, and that you do not send fluid anywhere to reach it.
So I would be careful and really figure what you just hooked up. Are you refering to the rubber line that is meant to hold coolant?
mitsuturbo
Near Seattle, Washington
Coolant gauge is usually the sensor on the FRONT of the Tstat housing. I believe that one is for something to do with the fans. I cannot quite recall what, though. It may be involved in the high/low switching of the fan circuits.
I do know for a fact that sensor is GVR4 specific. DSMs do not have it.
desant78
Clarksboro, NJ
Quoting doggietom:
i believe that is your sensor for your coolant gauge for your dash
what lead you to say this? because I am confused by which part of this picture has to do with hooking up a sensor for your dash? I could be wrong, so please explain.
stealthtt24
Orlando, FL
Quoting desant78:
It's hard to take a pic of. It's the single female/male connector behind the tstat housing.
desant78
Clarksboro, NJ
could you take another picture, and zone out a little bit?
mitsuturbo
I just looked it up in the FSM.
Here you go.
Keywords: coolant temp sensor sender thermostat housing sensors plug wire thermo switch coolant temp sender coolant temp sensor fan switch water temp thermostat housing sensors plugs sensor plug coolant temp sender senders pigtail wire wires
stealthtt24
Orlando, FL
Thanks, that's weird it was disconnected. We will see what happens tomorrow when I start it.
ktmrider
Tempe, AZ
Like mentioned it's the temp switch for A/C fan ( RH one from front ).
desant78
Clarksboro, NJ
Sorry about the placement of my messages, they weren't supposed to be so spread out. Good luck!
