Turn signals, lights out!!
Ok so last night my car started acting up. When I put my right turn signal with my lights on it will shut off all my lights, but not with my left turn signal only right. Any ideas what it could be?
Thanx
Could be a shorted bulb that is going straight to ground and pulling all your current.
It's wierd cause if I put the turn signal, like just push it a Lil not all the way the lights won't go off but if I push it all the way up lights go out. All my lights. I'm going to check the lever today. Just figured I ask if someone knew
Ok so yesterday I checked the car out. First I checked all my fuses had one burnt and two missing replaced them and my radio started working and my check engine light went out. Yeahh!! Then I checked my turn signal relay and replaced it but nothing same problem. So I took the car for a test drive to see if my check engine light would come back on. It didn't but my oil light came on. If I turned right it would go away. If I turned left it would stay on. And driving straight it would just blink. And I had just checked my oil. So I went home and checked my oil sensor, it was unplugged found the wire touching my down pipe. So I fixed it, thought that was my short for the lights but it wasn't still same problem. There's a relay in the engine bay for the headlamps and it clicks when I put the turn signal. So I'm thinking its that, gonna replace to see what happens. Also there's a couple plugs by the fuses under the dash that I have no idea what they are for, but I can't find the mating plugs to them. And the plug that goes on the clutch sensor by the clutch pedal was unplugged so I plugged it but car wouldn't start. I unplugged it and started right up. Don't know why. Any suggestions are greatly appreciated. Thank you again.
Oh and yes my hazards work fine and the lights do not go out with the hazards.
toybreaker
iconoclast
... sounds a lot like a loose ground /ubbthreads/images/graemlins/dunno.gif
raptorWagon
Oak Harbor, WA
That plug by the clutch pedal may have been the neutral safety switch, if you tried to start the car without pushing the clutch in, then that is why it wouldn't start when you reconnected that plug and did start when you disconnected it.
I plugged it and it did not start with or with out the clutch in. So I unplugged it and it started right up.
Also I know the axels with these cars and 1g Dsm are interchangeable. So my next question is are the tie rods and ball joints etc.. In the front end are they interchangeable with a 1g or are they gvr4 specific??
Ok update. Narrowed the light problem down to the light/turn signal/wiper lever assembly. Pick it up yesterday from Tom. Just finished installing and....... /ubbthreads/images/graemlins/grin.gif
Problem fixed. I'm so happy now. Haven't drove the car in a while cause I work at night. But man part work like a charm. Thank you again Tom /ubbthreads/images/graemlins/worthy.gif
