Transmission flush
Tre3zy
South San Francisco, CA
I have a spare transmission that i currently put in my gvr4 its been seating for a bit and i wanted to do a flush before putting a good trans fluid on it... Wat do you guys use to do a flush?
I used mobile 1 syntec. Oil on my motor and tranny and rear end.. To me is the best outhere if ur asking wat type of oil to use
4thStroke
Vancouver, WA
I would just use a cheap gear oil, drive a few miles and drain it. If the oil still looks fresh, add your oil of choice. If it looks pretty well used or separated, repeat until the cheap oil looks fresh when you drain it.
4thStroke
Vancouver, WA
For the flush, any 75-90 gear oil will be sufficient.
I'd use Redline MT-90 for daily use in the tranny.
gtluke
dirty jersey
I bet ATF would be an awesome flush. Not sure if anyone has tried that though but I've been tempted.
Tre3zy
Quoting brunoboy:
I wish I knew about this before, I'm near 600 miles on a fresh rebuilt stage 2 and I haven't flushed yet running mt-90/MTL right now =[.
I told you to flush that sh*t but you dont listen... Might wanna do it now
