Tranny problem
The_Big_Weave
Rapid City, SD
Having trouble getting the back of the tranny to sit flush. The bolt hole on the back is covered so I cant use that. any ideas? I am using the JDM switchable tranny if that helps at all.
The_Big_Weave
Rapid City, SD
I was thinking if I unbolted what I have bolted so far and then tapped it with a hammer to see if I could get to slide onto the pin that would work. It is just having trouble sliding all the way on to the pin on the back of the motor.
14u2nV
Agency/St. Joe, MO
yes, do that. Don't tighten it all till it's seated. You may have already oval'd out that pin though,, OR you may have the problem I had, and half of a pin is still in the hole where the current one is trying to go.
The_Big_Weave
Rapid City, SD
I dont understand where the rear bolt hole is I only have 3 bolts in and the front is flush because it bolted together. The rear only has about an 1/8 of an inch before it is flush.
