Tool quality question: how much for quality dial gauge?
Scott Y
Lakewood, Colorado, USA
I've spent too much time on the web looking at dial guages, and I can't figure out if I need to spend $200 on one to ensure accuracy, or not.
I was going to go through MSC, any other suggestions?
I'll initially be using it to do flywheel step measurement, but I can see at some indeterminate future date that I will use it for brakes/engine building/RC helicopters/some-other-stuff-that-I_haven't-thought-of-yet. So long-lived accurate performance is required.
How much have you guys spent? Where have you bought from?
Barnes
Richland, WA
I would just get one of the more inexpensive Mititoyo's or Starret's. Can't really go wrong there.
Muskrat
Lexington, KY
Also, remember if you want it to remain accurate it should really be calibrated at least once a year.
Dan D
Brownsburg, IN
For the general use stuff you don’t need to spend big bucks. I have a Fowler that was less than $50 and it’s good enough to 0.001”. I compared it to some brown & sharpe and starrett indicators our maintenance machinist has here at work. The expensive ones have a nicer feel to them and I imagine they hold up over time better without adjustment & calibration, but they were not more accurate.
Barnes
Richland, WA
Couldn't he attach his dial indicator to a flat bar?
Dan D
Brownsburg, IN
In my experience, a dial indicator and a fixture as seen here: RRE Flywheel Tech is easier to use than a depth gauge. There isn't a good a large flat reference surface on our flywheel to put the plate of a depth gauge against so you might accidentally rock it and mess up your measurement. $0.02
If you are using a depth gauge like this, there should be no rocking whats so ever.
