Synchromesh?
GM actually has and sells their own synchromesh. I'll get the p/n here in a minute.
GM synchromesh, P/N 12345349, not 100% sure if its used for the same application as the pennzoil stuff though.
3rdstrikedsm
32159, FL
If your car makes any type of tq then syncro mesh is way thin so try mt90 redline or better yet oem evo mr 6 spd fluid which is by far the best balance.
citymunky
Chesapeake, VA
Quoting Whoodoo:
zomg vfaq
I read that before I posted this. Here is qoute from VFAQ " GM Synchromesh (not actually produced by General Motors)". Since it's not made by GM I was wondering if Pennzoil made it.
Quoting galant1517:
In the back of the bottom it says its formulated for MT's used by GM requiring GM P/N: 12345349 ans 12345577.
DSM TALK link
Quoting Terry Posten:
That is what I used.
I think I'm going to try it, how does it shift?
Quoting 3rdstrikedsm:
My car is just a daily driver to me. My number 1 pritory is how the car runs day to day.
3rdstrikedsm
32159, FL
Be aware that it will for sure wear out your trans faster as there is minimal protection for the gear sets however it will shift faster/smoother for a while any how.
Syncromesh is a trade off for better shifting at the expense of longevity.
3rdstrikedsm
32159, FL
Haha because it's a mitsu but just run to your dealer and get some evo mr 6 spd diaqueen and you will be set or streettuned motor sports carrys it as well and I believe they even have free shipping this week or something like that.
It comes in a 1 gallon jug btw.
Terry Posten
Davenport, Iowa USA
As I said before, that is what I used and now, with the new EVO III tranny, I ran the first 500 miles with it and then swapped to Diaqueen.
And I am running a stroker with a PTE6152R, (just click on the link in my sig)...
Dan D
Brownsburg, IN
People talk about syncromesh wearing parts faster which may be true but - Prior to my rebuild last year, I ran penzoil syncromesh for 85k miles (on a 192k total mile trans) and the thing still shifted as good as it did when I switched from gear oil years and years ago.
(be aware that I drive the car hard, but I don't launch, race, or otherwise try to kill my drivetrain so you mileage may vary)
atc250r
Orange County, NY
We used BG Synchroshift at the first Mitsu dealer I worked at and we had very good results. I would use it again in a heartbeat but its easier for me to go into AutoZone and pick up a bottle of the Penzoil Synchroshift so that's what I've been using.
John
donniekak
surprise az
Anyone that rebuilds these transmissions can tell you it takes about 10 seconds to look at a bearing and know the owner used any of the "synchro" oils. If your transmission doesn't shift smooth, rebuild it. By using a band aid such as synchroshift, you are hiding the real problem, and causing more issuse down the road.
Synchros need friction to work, bearings and gear teeth need good lubrication. By using a synchro shift type oil, you are increasing the friction in the transmission. It can help a worn synchro work better, at the cost of possible catastrophic failure in the trans. A bearing that fails will ruin every gear in the trans, reducing your once grinding transmission to brick status.
slugsgomoo
Tacoma, WA
If you make power I would recommend not running more than 3:1 gear oil to synchromesh.
It will do nothing more than accelerate whatever problem you have. Nothing like draining fluid with the viscosity of water full of sparkles.
Just say no
Dan D
Brownsburg, IN
Not saying I disagree, but that's a pretty damn good bandaid in my opinion.
belize1334
Bozeman, MT
Taken from Jack's website...
Quoting Jackstransmissions.com:
DO NOT use Synchromesh, BG Synchroshift I or II, or Royal Purple. These fluids will destroy synchros and gears and void your warranty!
