Did a quick search but must've used the wrong keywords or something as I can't be the only one this has happened to?
Anyhow, went to open my hood the other day to show my friend the engine and the pull handle inside felt stuck..didn't want to risk breaking it using too much force so later on removed the grill and was able to unlatch it from the backside of the assy.
Well the latch assy seems to work fine but it's pretty difficult to get access on the exposed cable to see if it moves.
Thinking about removing the whole thing but not sure if thats a simple procedure as a lot ofthe cable is hidden. Also not sure if I should just replace the cable as don't want this to be an issue down the road.
Is cable still available at dealer and does anybody have pn handy?
Or perhaps the cable just needs to be lubed or something?
