Quoting Rausch:
I guess I assumed that if the plug was making as good a contact as it could, and the ground was either bad or the pump was drawing too much current, the weakest connection would show it first.
However, if the plug is only carrying the signal and ground for the rewire relay, then there really should not me much load there at all. Bad ground elsewhere would have all the current trying to get to ground through the plug, yes?
The fuel pump connector carries the power, ground and level sender voltage. Since the Denso Supra pump can draw 20A (twice the stock pump) or more, any contact resistance will cause heat and possible melt the plug.
People usually melt the cheap fuse holders before they melt the pump connector.
