Resevoir after 4bolt install
rallyvr4
Member
Tacoma,wa
So i removed all the rear steer and put a 4 bolt rear diff in im curious what people are doing for the power steering resevoir once you take out the rear lines.
EMX5636
Bucks County, PA
You can either cap them, or install a 1G DSM reservoir. If you're overseas and can't find one, I'm sure there is another Mitsu application that uses them, or try an N/A Galant etc.
NateCrisman
Blairstown, NJ
DSM receiver is exactly the part you want. no "hack" required. it bolts right in to the same bracket and only has 2 ports. simple/cheap/no-brainer
slugsgomoo
Tacoma, WA
I just capped mine since I wanted to keep the cap & sensor. Eventually I'll pull it, cut the ports off and weld them shut and repaint so it looks cleaner, but for now it's worked and no leaks for a long, long time (though not too many miles haha)
thomcasey
Indianapolis, IN
^^^This was my preferred method. Since I was able to have it cleaned and repainted, looks better than new and did not present a fire hazard during the welding. Then it looks stock
citymunky
Chesapeake, VA
Just get a 1g P/S reservoir. it only has 2 ports. I have a few laying around. /ubbthreads/images/graemlins/cool.gif PM
