Rear CV Joints
JackbNimble
Youngwood, PA
I need new rear CV joints for a '90 GGSX, however I can't seem to find them anywhere. Anybody know where I can find them or have a part number for them? Thanks.
Armitage
Herndon, VA
Are the joints really bad? If it's just a torn boot it's easy enough to clean them out, repack, and put a new boot on and call the job done. The rear CVs don't see nearly as extreme angles/wear as the fronts since the wheels don't turn much.
I don't know, perhaps click sells a rebuilt axle.
Otherwise, try your local junkyard or click
JackbNimble
Youngwood, PA
Well, they're clicking really bad. They've been clicking for over a year now and it started just when you would reverse and turn at the same time. Now it's clicking whenever you go forward or reverse and it even does it sometimes when the car is going straight and you disengage the clutch
