Need help with my altenator pulley
Logan981
New member
SW Michigan
There's been 2 other owners of 981 that have done heavy modding to it. At some point someone did the alternator position swap back to the firewall. My problem is the pulley used was WAY too big and misses the frame by maybe 1/16th of an inch, pic rel. What are my options now? It is running of the front pulley atm and, the belts seem to fit ok. What are my options to fix this? There is a good sized junkyard nearby and I'm willing to order what I need
diambo4life
Edmond, Oklahoma
Mine is pretty close to the frame (close enough to make slipping a belt on the pulley an issue with the engine in the car) but, it has never made any contact. It has been in there for years and this thing has seen hundreds of 9k rpm pulls. As long as your engine has good mounts (I have polys) it's not something to worry about assuming the kit was installed correctly.
slugsgomoo
Tacoma, WA
I did a little BFH massaging to the car where mine was because I was a little paranoid, but even with stock mounts and hitting the limiter on 2-3 shifts at 10,500 I don't have any marks from it hitting. Usually pulling the tensioner arm allowed enough clearance to sneak a belt through though.
is yours using the jay racing tensioner, or is it the older Buscher style? I can't tell from the pic.
raptorWagon
Oak Harbor, WA
That's also a GM/Saturn alternator, not your stock alternator that's been relocated fyi, common upgrade on these cars.
Could always remove alternator then massage out that area of the rail.
