moving maf
Hey guys just a quick question about moving the maf to the intercooler piping right after the bov. Would there be any ill effects to doing this? Would I need to doing anything else as far as tuning and stuff? thanks
Andy_S
Shithole Wisconsin
Can't do it with a stock maf. The only maf you could put post-turbo would be the gm maf. That would also need to be accompanied by a maf translator so your car can run it. You would be looking at around $100 to $200 for a setup like that.
ok that makes sense. thank you. all im really looking for is to run the bov 100% atmosphere. i know that the air is suppost to recirulate back into the in take and that the ecu compensates for that but would i be able to get the car for run good using just my safc to correct for the venting air?
Lonewolf64
Birmingham, Alabama
Quoting wickedwrx:
The short answer is no. Your SAFC can't correctly compensate for metered air being released to atmosphere.
ok thank you. now would the GM maf and maf translator be like a plug and play sort of deal or do you have to tune for that? can i run that in conjunction with my keydiver chip and safc?
The GM MAF and Translator is rarely plug-n-play. The output Hz can vary 20-30% depending how the MAF is mounted, what diameter pipes or adapters you use, and if there are any bends near the MAF.
