Motor mounts
Too general a question.
Do you mean the metal brackets that mount to the block and trans? Some but not all.
The rubber bushing parts? I think those may all be interchangeable.
And this is for AWD 1g, as FWD is different.
DynastyLCD
Harwinton, CT
as iceman said, the metal brackets that mount to the block and trans, the trans side and timing side are the same, but the front bracket that bolts to the block is different. its stamped with a 344. as far as i know, the engine mounts that bolt to the body are the same, but i think there was a member that had the avid mounts and they had difficulty with one of them and had to use a stock with poly insert.
SmoothCustomer
Lexington, KY
Ok, I have a follow up question to this. I know the 344 bracket is specific to the GVR4, and it seems that people believe all of the actual mounts (not brackets, MOUNTS with the rubber bushing) are interchangeable, but does anyone know for sure? I did a lot of searching and didn't find my answer. I have one from what I understand is a transmission mount from an awd DSM (does this matter for the mounts? I know it matters for the bracket) and it seems as though the mount itself will be higher up. I haven't measured or anything but it looks that way to me. It is interchangeable in the sense that it has that funky bolt pattern that matches the factory gvr4 but it seems as though the position is a little different. Any help is greatly appreciated.
Edit: Ok, looks like I have a FWD bracket here.
