maf translator pro
Looking for pros and cons on this system. i have an opportunity to get one cheap any help would be appreciated /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif
curtis
Clarksville TN
they work, there's a timing download you can use from there site and dependent on what all comes with it, if it has the 3 bar map and gm temp sensor and harnesses your getting a good deal. 3 bar maps are anywhere from 60 to 90 dollars 30 for the temp. Also if you can buy a wideband with it your set up.
Do a search under my name, Gordian79 and turbowop for the mas pro.
14u2nV
Agency/St. Joe, MO
If you don't know much about fuel settings, and don't have someone near you that does, I'd recomend not getting it. I gave up on mine after weeks of trying to get it set right, to no avail.
