So I'm trying to push through the miserably cold weather around here to get 642 on the road, but I keep getting plaqued by little issues. My AFC isn't booting up whick doesn't make any sense as I never touched its wiring and I verified that all the connections were solid(though some didn't look the nicest) before I retaped the harness. Figure its probably a loose ground or something simple but don't have a lot of motivation given the 30-40 degree weather.
My other major issue is that my dash gauges aren't working. Checked and it keeps blowing the 10 amp fuse. Replaced it several times and it just keeps reblowing at startup. Any ideas? I can't think of anything that I removed that would cause it to keep blowing. I wouldn't think that the AFC not booting would cause it, though they may both be result of the same problem.
