i swapped in 3 diff. maf sensors and still code 0012
yeti
san diego california
Is it the plug on the harness side?
The code came from nowhere about a month ago.
Just driving the all the sudden no revving past 3k rpms
Just wondering what else it could be?
donkeylips
Rochester, NY
My car is also throwing that code, along with #25. If you've used known good MAFs, then it must be your wiring or your ECU. The next step in my troubleshooting process is to check continuity between the MAF connector, and the ECU connectors. I'm using VFAQ to see which wires correspond to which(ECU pinout, and 2g MAF in a 1g).
yeti
will a multimeter be able to check for continuance,
And am I looking for a steady current?
I'm just a bit confused but understand the idea just don't know what tools are needed to perform test.
89Mirageman
Stantonsburg, NC
Are you getting a code for the temp sensor too? It would be almost impossible for 3 mafs to be bad. My guess is the caps are leaking on the ecu.
Terry Posten
Davenport, Iowa USA
Just use a multimeter and check the ohms on each wire from the harness plug at the MAS to the harness plug at the ECU. It should be a direct short for each wire.
If the harness checks out, swap in a different ECU and see if that is the problem.
yeti
I don't have another ecu to swap out but I'll check the harness and visually inspect the ecu.
I got a code for 0014 intake air temp. On one of the the 2g maf's
I really do appreciate all the help thanks to everyone.
chrisfullwood
bartlesville, ok
Maybe i'm missing something, but what kind of MAS are you using, have you swapped to a 2G/3G/EVO or is it stock?
If its stock, and the wiring harness is untouched, i would say as the other guys did, time to look at your ECU. You have to go with the most common component as the source of the issue.
I have had similar issues before, but its usually when i forget to plug it back in after messing with something.
yeti
I swapped in to diffrent 2g maf with a 1g to 2g plug and play harness.
And one 1g maf.
I'll be checking the car tommarow
