HELP!!!! Random oil leak coming from left bottom end
pudge76
Active member
Palmdale,Ca
i can not find the source anywhere and everytime i trun the car off oil is all over the driveway! /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/bawling.gif
Vr4junkie
Some wack town in CA
take some good quality day light pics it could be your (Crank seal oil feed line ect ect ) go buy some degrease and clean the engine bay and look for the leak.
How bad is the leak?
gvr4ever
central Indiana
Left front doesn't help much. Main oil leak problems are the oil pan, and turbo oil return line. The problem with oil leaks, it can kind of follow the shape of the oil pan and end up in a different place then the source, depending on how bad the leak is.
raptorWagon
Oak Harbor, WA
left front, oil filter housing is in that area and turbo, turbo oil seals could also be going, but I agree with the above statement too. Clean it up first and then see where its leaking from.
pudge76
Active member
Palmdale,Ca
the oil leak is coming from the back /ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif
