Fuel gauge doesn't work
alik
Boston, MA
rewired the fuel pump, now I can't figure out which wire goes where.
Help?
Diego
It would be on the bottom of the lid to the sending unit, where you have two brass studs. It's probably either you twisted the float arm or the you broke the wire itself/left loose/unhooked...
I just fixed my OE unit with #65 the other day...
alik
Boston, MA
Does it matter which wire goes where? There is a black with white stripe and yellow with blue stripe.
Thanks!
Diego
Yes, one wire coming off the float goes to one post which relays to the proper control,the other would be low voltage, I would almost bet that your low level light wouldn't come on either.
Switch the wires and see what happens. Also make sure the float arm didn't bind on the hanger. That could cause issue as well
Diego
