FS: Speed density set up
85tr
washington
Unbelievable , the wires were falling out of the dsm side if this harness and it was melted from too much heat and the iron touching it . Harnesses do not work when wires are not connected to each other . As I pulled the heat shrink off of the harness 5 more pins fell out of the dsm side of the harness because the plastic had been melted . The job is unrepIrable and I need to find a bad dsm ecu to rebuild this .
85tr
washington
He also never told me "it wasn't the prettiest in the first place" he told me it was professionally done and the tap job wasn't very good .
Professional job would not have a bad "tap" job. It would be all soldered. Aftermarket connectors are for wussies.
mitsuturbo
Near Seattle, Washington
Holy batshit. That "harness" looks like a tweaker worked for about 4 days on it without sleep, took a sh*t on it, wiped his buddies ass with it, ran it through the diswasher and then tried to "sanitize" it in a microwave.
If that's a professional soldering job, i should start soldering for a living, because even as a bit of a neophyte where solder work is concerned, i could do 200% better than that heap of sh*t with my eyes closed.
I don't think he even used a soldering iron. Maybe the tip of a screwdriver that was heated with a torch? I did better soldering work at the age of 8. Jesus H. Christ. /ubbthreads/images/graemlins/rofl.gif
85tr
washington
I'm not the best at soldering but have been doing it since I was ten on my r/c cars . I was doing better work then this back then .
Quoting mitsuturbo:
A post of epic description. /ubbthreads/images/graemlins/rofl.gif
