NateCrisman
EDITED: 7/7/14
Parting out my 92 AWD Auto DSM (red talon)... /ubbthreads/images/graemlins/bawling.gif No motivation to continue on with DSM stuff lately, and Iv moved on to a new "toy" car (Dodge Magnum SRT8 w/ blower). /ubbthreads/images/graemlins/devil.gif
this car went 10.7@128 on this setup w/ E85 in Fall of 2013. The car has been sitting on my lift since that day, due to an oil leak in the front case that developed on that run.
Please email me at [email protected] . I don't get much chance to check forums much anymore. Parts located in Blairstown, New Jersey 07825. Will negotiate shipping costs based on location and size/weight/packaging pita. Cash/Pickup encouraged!
Anyway, here is the list:
ARP head studs. $45
ABS Delete set (prop valve & 4 lines) $85
forward facing 6bolt oil filter housing $25
1g dsm radiator: $20
non turbo throttle body: $20 (no sensors)
valve cover $50 no cracks
alternator (rebuilt and clean) $50
CAS (91-92 green top) $35
91-94 coil pack $35
MPI relay $10
Front subframe w/ control arms. $50 ?
single piston front brake calipers w/ hoses $50
92 dsm headlighs: $30
92 dsm corner lights: $20
92 dsm turbo auto gauge cluster $15 135k miles.
GVR4 specific stuff:
4 lug front hubs: $50
4 lug front brake rotors for single piston calipers...GGSX I guess $50
$150 KYB GR2 shocks w/ Eibach prokit springs
Unorthodox crank pulley for 6bolt. $25
grant steering wheel $20
rebuilt 2G cyl head. Stock valves, valve train, lifters, rockers. $250. Ready to rock.
Apexi Catback 1g awd exhaust w/ slip fit test pipe. (minor surface rust on pipes, muffler is in pretty poor shape w/ a rust hole on bottom) $120
Spearco liquid/air intercooler "the crab cooler" w/ aluminum ice water tank, hoses, rule bilge pump....$385
Pic of water tank/pump coming soon.
3" intake pipe w/ air filter in fender (gotta cut hole where stock ic pipe goes) $65
SOLD
Megan Racing 3" Stainless Downpipe $100
DSMlink V3 w/ Eprom 92 ECU. $450
HKS 272 cams (nice condition...real HKS) - $280
FIC EasyTune box (think this bumps voltage to injectors to help with tune)... $155 shipped
FP exhaust manifold $125
AEM boost control solenoid $
AEM 5bar SS map & AIT Sensor (w/ plugs) $85
Aeromotive FPR w/ -6 SS hose to rail, pressure gauge, rubber hose to oem return pipe. $145
Walbro 255HP in tank pump $45
Autometer vac/ 45psi Sport Comp boost gauge $40
Fp3065 turbo, o2 housing, oil/water lines. $1050
Tial 44mm external. $185
FIC 1650s. $375
Evo3 intake manifold $130
MT ET Drag slicks (stupid cheap)
igniter/TPS
Front crossmember - Tube
JMF coil bracket
6Bolt bottom end, 1 2g head, AWD DSM fuel tank & sender, rear awd subframe assembly
2.3L stroker assembly
Tial bov replica
Konig 16" wheels and tires
Ingall control arms
Bosch 044 pump and -6 lines
second auto set
forced four shift box
TCU MD750092 : $100 (automatic trans computer from 92 awd)
ISC motor
VOLK wheels
Innovate wideband
ARP headstuds
Fluidampnr crank pulley
ARP head studs. $45
91-94 coil pack $35
MPI relay $10
SOLD
FIC 1650s. $375
igniter/TPS
JMF coil bracket
Tial bov replica
Ingall control arms
second auto set
ISC motor
VOLK wheels
Innovate wideband
ARP headstuds
