FS: 1991 654/2000 Nor Cal $8,000obo
Status
Not open for further replies.
uncleben4rice
antioch ca,
car 654/2000 10,000 miles since rebuilt all that is needed for this car is big turbo...I just bought a Harly so looking to sell this toy...short mod list
dsm link
272 hks cams
750 injectors
stage 2 tre tranny
wideband
9 to 1 je pistons motor race built capable of 30psi
every thing you need to run big numbers all you need is the big turbo...all the nor-cal group knows whats in this car... I spent over 11 grand last year on mods car runs great asking $8,000obo
the motor and tranny cost me $6,000 last year alone..
Sr71sss
by the river next to the delta
The car needs just a very good tune and a little more TLC and this car will be a true high 11 low 12's sec car, he has driven the car everyday as I can vouch for it since he is my good friend and neighbor, the car has a long list of other things he has yet to tell but I'm sure he will fix that right...
Bump for a really true drivers car as some off them are never driven to its full potential
conrad
rheckert
Indianola, Iowa
More info please.
Body miles, interior shots, current turbo?, sunroof?
Looks nice from the single pic but more is needed to justify 8K IMO.
uncleben4rice
antioch ca,
POWER MODS
rebuilt motor $4,000
tre stage 2 tranny $1,500
HKS cams 272/272
JE 9:1 Pistons
crower valvetrain
Weapon-R Foam filter - $30
2G MAF
Griffen 20x10x2.75" Intercooler core with HKS Endtanks - $450
TCToons 2.5" Intercooler piping from Turbo to Throttle body - $300
TRE ported Mitsubishi small TD05H-16G turbo w/34mm Wastegate valve - $775
TRE Ported 95+ Exhaust Manifold - $200
TRE Ported 95+ o2 Sensor housing - $125
dejon manual boost controller -$60
TCToons 3" Turbo back exhaust with Thermal muffler - ~$700
Removed silencer - $0
EGR Blockoff plate - $0
NGK BP7ES spark plugs - $6
NGK 7MM spark plug wires - $45
Walbro 190lph Fuel Pump - $130
Spoolinup Adjustable fuel pressure regulator - $120
Rewired fuel pump power wire - $15
RC 750cc injectors - $320
ACT 2600 clutch - $385
RRE lightened flywheel - $125
BG Syncroshift gear oil - $8/qt
Redline MTL 75-90 in rear diff
Symborski Shift Kit - $20
RRE Stainless Steel Turbo oil supply line - $55
RRE Stainless Steel Clutch line - $20
SUSPENSION MODS
Mofugas Front adjustable strut bar - $75
Mofugas Rear adjustable strut bar - $75
Mofugas Whiteline 24mm rear sway bar - $125
RRE Stainless Steel Brake lines - $110
KYB AGX struts - $320
DSS Coilover 400F/350R 8" springs- $400
4-bolt rear axle from 92 DSM
5-lug hubs from 92 DSM
MISC MODS
Apexi EL 60mm Peakhold EGT - $250
Apexi EL 60mm -30-0-30psi Boost gauge - $155
AutoMeter Phantom Electric 0-100psi Oil Pressure gauge - $45
AutoMeter Phantom Electric 100-250degree Water Temp gauge - $55
AutoMeter Phantom Electric 0-100psi Fuel Pressure gauge - $80
Lo-Tek Engineering dual gauge pillar pod - $40
Mofugas Motorsports single DIN panel triple gauge plate - $20
Mofugas Motorsports Leather Shift Boot - $40
Zeitronics wide band A/F Meter $400
DSM link $525
Greddy Turbo Timer - $50
2G shift knob - came with car
1G T/E/L shifter - $25
Razo pedal covers - came with car
Spal 11" 810cfm slim fan - $66
Homemade Intercooler Sprayer - $20
Battery Relocation kit - ~$100
this is an old list of all that is on the car I have done other mods as well not listed like new timing lower cover -$100
too much other stuff to list..if I get the $8,000 the car would go to Conrad to installe the other parts needed...like the new axels that are in the trunk...altenater and belt were just replaced last week...it has new tires..ect..ect I will take pics of intee and imperfections this weekend...if you want a monster save yourself some cash and buy this car...im getting a prius after this...I was going to buy the FP3065 and go 11s with this setup..but GAS 4bucks a gallon. yea right...the car gets about 23-25 MPG now oh and no A/C its to fast for that..LOL... the car is fast for a small 16g car.. it has smoked some Mustangs and Evos on the street and run high 13s at the track...I will provide smog cert with sale...put the cash in my hand...
Sr71sss
you forgot to mention the Evo 8 oil cooler setup, btw this setup blow the so called aftermarket coolers that cost 3 times more than what I did it for and plus it does not leak at any of the connections, no earls or russells braided lines, all done for $72 with fittings and hoses!!
Bump for a proven drivers car all it needs is a little more tlc
Conrad
Olson
Moreno Valley CA
this is a really nice clean car good paint good interior. just needs little stuff here and there and itll be a fast fast car
Nice car, and by the way...
This car is fairly close in performance and money spent to my car, irony.
Also "U R Who your friends R" maybe suggests that some clown had the car before, and didn;t do it justice. Is that correct?
If so I think you got a twin on the east coast!
Bump for a Solid GVR4
Sr71sss
what this car hasn't been sold yet, man I'm shocked since this car really needs nothing else except some tlc
bump for a real street driven vr4 with real street miles!! /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
conrad
Status
