decided to get a newerish car and get out of the modding game for good. i've been daily driving it since early december with no probs. runs great and its pretty fast. everything on the car works from a/c to cruise control. interior leather is mint with no rips. interior is very clean also. comes with a pioneer radio. here is a list of mods:
Whiteline Sportline Springs (If I remember the model correctly)
KYB Struts and Shocks
3 Inch Turbo Back Mofagus Exhaust, installed back in 2002. It has a cat so its not that loud.
550 RC Injectors
Keydriver Chip and Capped ECU set up for the currect mods
2nd GEN MAF and intake tube
EVOIII 16G , still boosts excellent
Rear Steering Blocked off. The rear lines were leaking so I removed them.
EVOIII Exhaust Manifold
Ported O2 Sensor Housing
ACT 2600 Clutch
Converted the high lamps to HID
Custom FMIC with custom piping with HKS (I believe) Adjustable BOV
Custom Manual Boost Controller
S-AFC II Installed last Spring, Tuned the car to 235.9 WHP on a Dynojet
Recently replaced the Valve cover and Valve Cover Gasket
Walbro 255 Fuel Pump
Timing belt/ Waterpump was replaced at 130K
Dash Lighting Works in both colors
Factory JDM Hood with vents.
The Battery has been relocated to the trunk.
I had the car custom painted with a custom metalic paint 4 years ago. It almost looks like the green and then it will look black in other lighting.
the bad:
-car has dent on hood and fender from previous owner hitting a deer, not that bad but replace for perfect look
-1 front caliper is seizing (pair of front calipers will be provided)
-ebrake cable needs to be replace or leave car in gear when parked
-needs abs relay for abs to work. light is on at the momment
-needs a new blower relay for blower fan to come on when switched on. if not car will turn blower fan on when the current relay makes enough contact to pass current.
extras:
-set of rims that look like this (not my car)
-some new rear brake pads
-set of front calipers
-new master cylinder
-272 degree cams
-750cc RC injectors NIB
-93 galant clear headlights
By wildacex187
By wildacex187, shot with KE990 at 2009-01-24
By wildacex187 at 2009-01-24
By wildacex187, shot with KE990 at 2008-12-24
By wildacex187, shot with KE990 at 2009-01-01
550 RC Injectors
ACT 2600 Clutch
the bad:
extras:
-272 degree cams
By wildacex187
