Factory turbo gauge
RedTwo
New Zealand
Assuming I'm reading the ecu pin outs correctly, does anyone know what voltage/ampage the little factory turbo boost bar graph inside the tacho runs on? ie: x volts/amps per bar?
It doesn't work on volts or amps. It is pulsewidth modulated to ground by the ECU. I'm sure you could probably activate it also by a variable voltage, but that isn't how it is operated now. One side of the gauge is +12 vdc, the other connects to the ECU, to a driver chip, which is controlled by the CPU.
RedTwo
New Zealand
Well, I don't have a MMC ECU so it doesn't do anything at the moment. I spotted that the Innovative LC-1/DX-16? has what I understand to be an adjustable/programmable secondary voltage out put. My plan was to hook it up to the dash gauge, but it sounds like it wont really turn out.
belize1334
Bozeman, MT
You just need a little rc circuit that will turn a voltage into a pulse-width. You could make one with a 555 timer chip and some resistors / capacitors. Otherwise I'm SURE that you could buy one pre-made. The issue will just be getting the voltage to PW curve to match up to the LC1 output and the gauge input.
stevep
St. Charles, IL USA
I'm pretty sure that the LED display has a capacitor somewhere that is converting the pulse width into a voltage and the display turns on the LED in response to the voltage.
