Factory Spec wheel alignment
Does anyone know what's the factory spec wheel alignment? Like the degrees for camber, toe, etc.
Turbo4door1
Kearneysville, WV
Front:
Camber between 0 and 1
Caster between 1.44 and 2.44
Toe between -.13 and +.13
Rear:
Camber between -1.50 and -.50
Toe between 0 and .25
Sorry, but I don't think front camber is adjustable on stock GVR4s. You getz what you getz.
Why is the front camber positive???? I just got my alignment from the dealer and they told me the same thing. Isn't it better to have 0 - (-.5) degree camber in the front??? My front tires look kind of tilted and the outer treads are getting rounded out a bit. Should I take it back and have them redo it???
markrieb
Kennewick, WA, USA
You can get some negative camber from the stock suspension.
Try the following for performance street driving. This should not be hard on tires, but if it is, add some toe *in*.
Front camber: -1 to -1.5 degrees each side
Front Caster: Non adjustable from the factory, but do yourself a favor and get the cheap (~$35) Whiteline offset caster bushings and get as much Caster as possible
Front Toe: 0. If your tires can stand the wear and you want quicker turn-in, go with about 1/16" of toe out. If you start to see feathering of the inside edges of the tires, you can go to 1/16" of toe *in*.
Rear Camber: -1 to -1.5 degrees
Rear Toe: 0
These numbers are just inside the factory specifications.
Make sure you bounce the car a couple of times after setting the camber and toe, then double check the numbers.
Also make sure the tech follows the technical service bulletin on the rear about disconnecting the AWS rams to set the rear. If it doesn't show for the GVR-4, have them look in their book for the 3KGT VR-4 as it is nearly the same system.
For autocrossing, increase the front camber to around 3 degrees or more and toe the front out about 1/16". If you need to loosen up the rear a bit, you can toe it out some too.
Mark Rieb
Mark Rieb
aw crap where can i find a tsb printable version of this? I just got an alignment today and im off in the front left camber.
number3
KoP, PA
Rear Toe: 0
Mark Rieb
Mark,
What would you change (above) with TEINS? I would like to get this setup this week.
Harry
markrieb
Kennewick, WA, USA
Harry, I don't think I'd change anything for normal street use. Open track settings fall between the street and autox settings. A car optimized for autox will be twitchy and jumpy on a larger, higher speed track.
For as few miles as you put on your car, and if you are willing to put up with a little tire wear for better performance (or if you drive hard enough for it not to make a difference...), I might go a bit higher on the camber, maybe 2 to 2.5 degrees negative in front, but stay around 1.5 to 2 in the rear.
You can also toe out the front about 1/16". This will really sharpen turn in, but will make the car a bit twitchy and it will want to trammel/follow the grooves in the road. If the car is too much on an open track, turn the toe back down to zero. Leave the toe in the rear at zero.
I don't know how much caster the Tein's allow, but pretty much go for all you can get.
If you are real serious, find somebody with some wheel scales and use them to set your coil over heights/corner weights. Mike C. at DSS had some numbers somewhere on where to set your corner weights.
These setting will be a bit hard on tires if you do much highway driving, but should balance things out nicely on the track.
Mark
Mark,
I just installed a set of H&R / AGX combo (GVR4 Specific) I am going to get my car aligned soon should i follow factory spec?....
I am looking to get even tire wear as my car is my daily at this point
And in order to get my vehicle in spec am i going to need camber hardware for the front and the back as well?...
I had my eye on this for the front eibach front camber bolts
and this for the rear whiteline rear bushing camber kit but they are currently out of stock on the rear's
should that hardware do the trick?...Or can i get by without them?...
Thanks,Dave
number3
KoP, PA
I plan to corner weigh the car (the reason for the Teins). Do you think you could round up those numbers for me that Mike published?
I also can not seem to get the front of the car to come down. It seems to want to stay at 15 1/2" from hub to fender. Any ideas why?
Harry
Mark Rieb
Try this link:
http://www.dsmchips.com/~keydiver/gvralign.pdf
http://www.dsmchips.com/~keydiver/gvr4_tsb.pdf
Jeff O.
[ 07-30-2004, 09:13 AM: Message edited by: keydiver ]
markrieb
Kennewick, WA, USA
Dook,
Follow my original settings 1 to 1.5 degree of negative camber all 4 corners, zero toe at both ends. You shouldn't have any unusual tire wear at these settings. But, make sure you bounce the car between settings and double check them and use the TSB for the rear AWS.
Harry,
I'll dig for the info, but I'm restricted to a phone line at work. Give me a day or so.
Mark
number3
KoP, PA
Harry,
Mark
No problem. I am taking the car on Monday to have the work done.
Thanks,
Harry
markrieb
Kennewick, WA, USA
Harry,
I couldn't find anything easily. Your best bet is to call Mike at DSS.
For Order & Tech Calls: (805) 541-4483 Fax Number: (805) 541-7165
Sorry,
Mark
sorry to hijack: (I am totally ignorant with the suspension knowledge)
Had the wifes aligned a few weeks ago and it sucks. After replacing the tie rod ends, alignment shop did there work and it pulls to the left very noticeably. They rotated the tires and said it was set to factory spec. It still pulled to the left (less but still noticeable) and the rear camber or castor (always get those confused) looks like a 400lb person in the back it angles in so much! Funny that it doesn't pull so much to the left when on the throttle firmly...I'd bet that's how the tech test drove it
so he didn't notice it as much...
I need to take it back, but I don't know jack about the specs and was just going to put one of the guys in the car and let it vear left towards oncoming traffic while he tells me it's o.k.!!!
Ignorant me...I don't know if they did any of it correctly. It drove better from the "guestimate" after the R&R on the tie-rods in the garage.
Kevin,
Major contributors to pull are:
Uneven caster (fore/aft angle of front susp),one side may have been pushed back.
Uneven camber (called cross camber on alignment equipment) with measurements too far from nominal in opposite directions or out of spec one side,
Rear thrust angle causing rear steer input (incorrect or biased one side rear toe-in usually)
Bad tire.
Were the rears brought to the front possibly?
( I had this on my minivan with one dodgy tire that made its way to the left front).
Typically, with front camber and toe "not adjustable" from the factory, most alignment techs will leave them where ever they are, even if not very good. Since the car was tweaked (this is the one from the deer incident, correct)you may need some "abnormal" settings or adjustment equipment to make it work right.
Thanks David,
This was right before the 'deer adjustment", but who knows, maybe the car had previos adjustments.
The tires are fairly new.
I guess I'll have to see if they can set it where it works for just this car or maybe another shop that can.
Are some of you guys doing this yourself? If so, how involved of a process is it...special tools, etc. Uggh, it maybe one of those other things I have to learn to do myself only because I don't trust a local shop to do it!
TIA again.
ken inn
krum texas
yo, kevin, i KNEW my car was slightly off, and i took it to a body shop with a laser frame machine. just to put it on the machine costs 45 bucks, then it is hourly from then on. they verified the frame was off, and they could not pull it straight. they ended up putting ingalls kits on the front, and trued it to spec. huge difference. total was 350, but from now on a total alignment is only 70 bucks, because now they know the settings. they gave me back all kinds of printouts on what was done, and what is supposed to be there.
