EGT sensor
presterone
brunswick maine
Where in the exhaust manifold should I install this thing? I have a FP manifold for an evo 16G looks like unequal length runners. Pics would be a plus thanks!
moneypit
bothell, wa
Cyl 1 runner. Its the last cyl to get fed by the fuel rail & cyl most likely to starve for fuel.
presterone
brunswick maine
What if there is an issue with other cylinders will it not be inaccurate? I've decided I want to get another flange made in between the manifold and turbo, Won't this be the most accurate? since it won't be on a dedicated runner.
Jason G.
Anderson, SC
I think you may be expecting too much from this gauge and would be better off using a wideband.
You'll get an actual AF ratio vs. a high temperature reading and still unsure if it's lean or fat.
