...then the values on the timing map are all+5 as well, right?
EfiniX Well-known member Joined Oct 18, 2012 Messages 647 Location portland, or Jul 3, 2015 #1 ...then the values on the timing map are all+5 as well, right?
turbowop Well-known member Joined Apr 29, 2001 Messages 11,982 Location Yakima, WA Jul 3, 2015 #2 No. ECU assumes your base timing is correctly set at 5 degrees. So the numbers it puts out are based on that.
EfiniX Well-known member Joined Oct 18, 2012 Messages 647 Location portland, or Jul 3, 2015 #3 Glad I asked, although my running has been based on AFR's and knock, so really, it's just so I know where I'm at.
Olson Well-known member Joined Oct 7, 2006 Messages 1,237 Location Moreno Valley CA Jul 3, 2015 #4 Quoting EfiniX: ...then the values on the timing map are all+5 as well, right? set it at 5 start the car advance it via link 5 its now 10 total
